Any one have dimensios for
Old Oct 23, 2005 | 07:25 PM
clarence-nieuwhof's Avatar
clarence-nieuwhof
Default Any one have dimensios for
I need to build a frame jig for a 1973 , I was wondering if any one here has had to build one and would have a drawing or matrial list. I'm just not sure how heavy the I-beams should be. I was planning on flipping the frame and mounting it at the body mounts. I have some major frame repair to do and want to keep it square. Or just buy another frame but I don't mind the challenge either , I searched the site but couldn't find any info
Old Oct 23, 2005 | 08:37 PM
LYLE's Avatar
LYLE
You could tack weld it to the I beams on #-2-3 body mounts and then weld braces off the beams to the front and back. Brace it good where you cut the frame.When done grind off the welds. I would look for a new frame or the front or rear section. I have a rear section in NW ohio.
Old Oct 23, 2005 | 09:37 PM
MikeC's Avatar
MikeC
Sounds bad Clarence!
You saw my car, it was in the same shape as yours sounds to be in. I found it easier to replace the frame than repair the old one.
There is a drawing around here... with measurements... I'll dig it up and email it to you. where is the frame bad? I stil have the front half of my old frame as well as tranny crossmember that's yours for the taking if you need it.... But I assume its in the back of the frame where the major issues exist though.
Old Oct 23, 2005 | 10:48 PM
clarence-nieuwhof
Does the rear section of frame include the the cross member that goes across right infront of the rear wheels.
Old Oct 23, 2005 | 10:55 PM
clarence-nieuwhof
Ya its on the drivers side in front of the rear wheel and I think I may be looking for a frame. What sucks is I spent a couple of hundred bucks sandblasting to find this out.
Old Oct 24, 2005 | 08:50 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Call me up and I can fax you frame specs if you need them.800-418-5397 - Dan
To Any one have dimensios for
