U-Joints ???
Texas. Price is for 4 of the 1/2 shafts only!!!
Good luck,
Gary
http://www.rb-wholesale.com/default.isg?cPath=228
http://www.dragvette.com/
Thanx,-Pete.
KEEP DRIVING!!!
Thanx,-Pete.
KEEP DRIVING!!!1. Spray u-joint bolts with nut loosener the night before.
2. Jack up the 'vette until the rear tire on the side your are working on just leaves the ground. Use hydraulic jack or jackstand and chock the front wheels. Mainly because you need to put the transmission in N.
3. Cram a big screw driver under the tire so it won't turn when you loosen the u-joint bolts.
4. Remove the 4 nuts on the 1/2 shaft where it a attaches to the rear end. Remove the U-shaped bolts--gentle tapping may be required.
You'll have to keep turning the tire to get off all four bolts (for clearence)--that is why you stuffed the screw driver under the tire--pull out the screw driver from under the tire, turn the tire, then stuff the screw driver back under it.
5. Now go to the u-joint flange and press down the tabs on the french locks--if your car still has them.
6. Remove all four bolts.
7. Gently push out and wiggle on the tire so the u-joint flange clears the spindle nut (it's under the flange.
8. At this point the 1/2 shaft will fall right out--watch out!
Took me about 30-45 minutes for each side and most of that was wrenching the bolts and nuts. I didn't have to get out from under the car at all. The nuts and bolts are 9/16". This is the first time I've done this too--so I was quite relieved it was this easy.
They're better looking in person too-the Spicer u-joints are already installed--just bolt'em in.
the ubolts off.
Lock washers were stuck to the yoke head and were hard to see from the grease:
french Locks were missing, so I used Lok-tite.
yeah, they all came off. guess I'll try a bigger hammer/screwdriver, guess if that does not work, I will have to cut them or something.
I wouldn't cut the u bolts....with lockwashers removed put the nuts back on so as not to ruin the threads and
lightly.
lightly.
lightly? how ? theres a differential les then half in inch from where the nut is. I must be missing something. I can't get anything in there to hit or push with.What I had been trying is to put the screwdriver on the bent part of the U bolt, and
very hard.
/end noob mode.
But the at least the shaft dropped easily. Anyway, thanks for the above responses.
JCJ
