U-Joints ???
Old Oct 31, 2005 | 09:34 PM
  #41
jdmick's Avatar
jdmick
Originally Posted by Nvts
Yeah, I think I give up, time to go buy something to cut the bolts
That's what I'd recommend. Go to Harbor Freight or similar store and pick up a $20 4 1/2" angle grinder along with some cutting (not grinding) blades. Since you're replacing the u-joints anyway go ahead and cut the u bolts without worrying about getting into the u-joint. Leave some sticking out to try to twist out whats left. You could also cut them flush with the yoke and punch what's left out.
Old Oct 31, 2005 | 09:59 PM
  #42
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
[/QUOTE][/QUOTE]
I've never seen 1/2 shafts w/weights on them. From the pic it kind of looks like the yokes are squared up. Do the shafts rock a little if you lay them on the ground?
