2nd Gear Uh oh
Old 10-24-2005, 01:12 PM
Clint's C3
Clint's C3's Avatar
Default 2nd Gear Uh oh
We were bracket racing at a local 1/4 mile strip. I adjusted the TV cable on our T700 R4 trans to allow it to shift at 4800 rpm vs ~ 5500 when set per specs.
We made 4 passes, dial in plus winning 2 rounds, at consisatnt 15.5s. 3rd run my son cut a good light and was leading until ~ 3/8 mile. The time was 16.1 (WTF?).
He said the trans shifted to second, revved to ~ 3500 and then started slipping as if in neutral. He shifted to neutral and back to drive and no more slipping. I adjusted TV cable back to specs and have been driving with no problems. Any ideas???
Old 10-24-2005, 04:13 PM
neoh77
neoh77's Avatar
do NOT change shift points of a 700r4 with the TV cable. you may have already done that tranny in actually.
http://www.transmissioncenter.net/subject.htm
read number 6 in particular. There are springs in the governor that control the WOT shift points. I believe you need to measure line pressure to properly set the TV cable.
-Matt
Old 10-24-2005, 05:56 PM
Clint's C3
Clint's C3's Avatar
Thanks for the link.
I'm going to order a
700R4 Shift Point Package. This kit allows you to raise or lower the shift RPM.
And hope I didn't hurt my baby too bad.
To 2nd Gear Uh oh
Quick Reply: 2nd Gear Uh oh
