some steering assembly questions
Old Oct 26, 2005 | 03:42 PM
panchop's Avatar
panchop
Default some steering assembly questions
as i don't want to be misdirecting anyone elses thread. for my 75 pro street/ strip car. blown big block, back halved, fats and skinneys. I am researching what to do with the front end. evryone likes rack and pinion but i do't know that i will have any use for it. i will either be cruising slowley and crawling around corners or be flat our going straight on a drag strip.i know i want to dump the wieght and associated problems of power streering. talking to "corvette steering " he says all i need is to change out to a manual drag link. so i was thinking maybe tubular a arms and a change to manual is all i wll do. any ideas out there.
greg
Old Oct 26, 2005 | 11:14 PM
Jim Shea's Avatar
Jim Shea
If weight is your major consideration, then install a Steeroids center take off type system with a manual rack and pinion gear. The original Cavaliers and Sunbirds did have manual rack and pinions available. They will bolt right into a C3 with the Steeroids brackets. The input shafts were not the same as power R&Ps however.
Old Oct 31, 2005 | 12:57 PM
panchop's Avatar
panchop
so anyone know where i can just buy some brackets? or at lest get a good look at a set.
Old Oct 31, 2005 | 02:17 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
<--- Click the Chick, go to my home page and follow the link to Rack and pinion.
Center bracket Dims have to be updated tho, Maybe tomorrow night...
Old Oct 31, 2005 | 05:10 PM
panchop's Avatar
panchop
perfect, thanks.
greg
To some steering assembly questions
