Lower a-arm problems
Old Oct 29, 2005 | 02:14 PM
vette_81's Avatar
vette_81
5th Gear
Default Lower a-arm problems
Looking over the suspension in noticed the welds on the lower a-arm are cracked, what should i do about this problem. I auto-x and begining to do some road courses so I need it to be strong.
Old Oct 29, 2005 | 03:50 PM
Twin_Turbo's Avatar
Twin_Turbo
which ones are cracked? only the sway bar bracket is welded on, the steering stops and the 2 little nut plates for the shock. The rest is stamped steel..unless you're talking about VB&P arms in which case you're the 2nd person in short time w/ cracked lowers.
Old Oct 29, 2005 | 05:45 PM
vette_81's Avatar
vette_81
5th Gear
It was the welds from the lower a-arm bracket to the frame that cracked.
Old Oct 29, 2005 | 05:46 PM
Twin_Turbo's Avatar
Twin_Turbo
oh common problem, you need to properly weld them on the sides, not only the factory spot welds and then add some gussets front and back
Old Oct 29, 2005 | 05:47 PM
norvalwilhelm's Avatar
norvalwilhelm
This is a very common problem and most of us have welded these channels on . They are originally spot welded on and rust gets in there and pops them off. Clean the area and get someone to weld them up completely. It is also a good idea to put small gussets in the entire area. At the very least weld the channels on both side.
To Lower a-arm problems
