AC Questions...
Old Nov 4, 2005 | 10:09 PM
enkeivette's Avatar
enkeivette
Default AC Questions...
Well I need to replace my heater core, and from the looks of it I should probably replace my AC hoses/ lines while I'm in there. (They leak right now). Right now I have the stock setup and the old R12 I think it's called and I have to convert to the R34... I think it's called.
To convert do I use the same compressor and condensor?
Should I just buy the metal/ rubber lines made for my car? Or do I need different lines for the conversion? (R34 setup)
Also! Is there any thing else that needs to be replaced? Some part of the AC system that I might not know about?
Old Nov 4, 2005 | 10:18 PM
zwede's Avatar
zwede
You don't have to convert to R134a. R12 is still available, although more expensive.
If you do convert: Yes, same condensor etc. If you buy new hoses they are R134a compatible. Replace all O-rings (you should anyway).
You will need a new drier regardless if you do R12 or R134a.
Old Nov 4, 2005 | 10:25 PM
Russ Bellinis's Avatar
Russ Bellinis
R12 is still available but you have to have a federal license to buy it. You can save some money by doing the mechanical work yourself and then taking it to a shop to have the unit leak checked, evacuated and charged. If you want to do it yourself, you will have to convert to r134a. If you do the conversion, you will need to remove the compressor, drain the oil, replace it with polyolesther oil (POE).
Old Nov 4, 2005 | 11:21 PM
enkeivette's Avatar
enkeivette
I'm ok with using the R134, don't want to hurt the ozone any more than I already have to so that I can enjoy this car.
And what is a drier?
Old Nov 5, 2005 | 12:30 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
you can get the R12 on ebay but "for export only"
I know two guys who converted from R12 to 134a and both say the AC performs as well as it did before. It seems there is no reason not to convert... you'll have to install new seals (o-rings), replace the hoses depending on their age and condition...
here's a good example of a aftermarket AC:
Old Nov 5, 2005 | 12:48 AM
ewalker302's Avatar
ewalker302
I have done the conversion in a couple of my cars.
All I did was let the old out, get a cheap kit a AZ, and go in with the new.
Both are still cooling great 2+ years later.
Old Nov 5, 2005 | 04:09 AM
Russ Bellinis
The drier is the accumulator/drier, that big aluminum tank looking thing on the right end of your firewall in the engine compartment. One other thing to change is the orifice. If you look at the hose that runs from your condenser (the radiator looking thing in front of your radiator) to the accumulator, you will see a crimp about 2"-3" up from the fitting where it fastens to the accumulator/drier. If you open that fitting, you will find a plastic piece with a screen in it sitting in the line. The crimp keeps it from moving closer to the condenser, and the fitting locks it in place on the other end. The orifice is the "brains" of your a/c system. The accumulator/drier will probably cost about $70.00 or so, the orifice is less than $10.00. I do refrigeration for a living for the last 30 years, feel free to ask any questions.
Old Nov 5, 2005 | 04:53 AM
enkeivette's Avatar
enkeivette
OK cool, and the drier is behind that fiberglass panel that covers the heater core I'm assuming?
If so all the more reason to do this while I'm changing the heater core.
Old Nov 5, 2005 | 05:04 AM
Russ Bellinis
No the drier is inside the accumulator/drier. It has a chamber that is filled with desicant.
Old Nov 5, 2005 | 10:15 AM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
Russ, I am converting a non A/C car to A/C using Corvette components and 134a. I bought a new "variable" orifice tube for my A/C. It seems the original fixed tube was color coded. How do I know I have the correct "variable" orifice?
Old Nov 5, 2005 | 12:29 PM
Russ Bellinis
That question stumps me. I work primarily with refrigeration where we use thermal expansion valves instead of a fixed orifice. Where did you get the variable orifice? If you got it from a reputable automotive a/c shop that does work on older cars or from a G.M. dealer, it is probably right. If you got it from an auto parts store, I would stop by an automotive a/c shop with the orifice and ask them about it. Most shop personel in my experience don't mind answering questions like that for people if the one asking doesn't come off as a total idiot.
To AC Questions...
