Rear Bearign Rebuild
Old Nov 14, 2005 | 11:00 AM
Garys 68's Avatar
Garys 68
I'm trying to figure out if it's worth it for me to rebuild or send them out for rebuilding.
What's the total cost of parts, bearings, seals, shim kit, bushings, etc for a rebuild?
What's the cost of special tools? ie, $99 for setup tool, bearing separator, etc. if I've already got a press, dial indicator, micrometer.
Gary
Old Nov 15, 2005 | 10:55 AM
Garys 68's Avatar
Garys 68
Have not taken mine apart yet. Just making a list with expected costs.
Parts:
Inner/outer bearing
Inner outer seals
bearing spacer shim kit
Trailing arm bushing/sleeve
Backing plate (seems like everyone replaces these)
Parking brake shoes
Turn brake rotor
Tools:
Bearing setup tool
Bearing separator
Did I forget anything?
Gary
Old Nov 15, 2005 | 01:04 PM
GTR1999's Avatar
GTR1999
I'll PM you some info. You don't want to turn the rotors unless you need to.
Old Nov 15, 2005 | 01:13 PM
Gordonm's Avatar
Gordonm
Those are purdy. Nice work Gary.
Old Nov 16, 2005 | 01:40 PM
Burnt71's Avatar
Burnt71
ttt
Old Nov 18, 2005 | 12:35 PM
GTR1999's Avatar
GTR1999
So did anyone do this job yet?
Old Nov 18, 2005 | 02:13 PM
Garys 68's Avatar
Garys 68
The weather is still good here in St Louis.
I'm waiting until it gets garaged for the winter.
Old Nov 18, 2005 | 06:55 PM
Twin_Turbo's Avatar
Twin_Turbo
LOL the seal is on backwards
Steve's74's Avatar
Steve's74
I hope to begin work over Thanksgiving weekend on mine. Unfortunately, it's been over 25 years since I've had one of these apart, so I can't see the problem in your picture. I assume that you washed the grease out of the bearing and that it didn't come apart that way.....
Steve
:edit: Damn TT! I told you it had been to long!
Old Nov 18, 2005 | 07:07 PM
GTR1999's Avatar
GTR1999
Hah HA, Zwede wins it!!!!!!!!!!!!!!!!!!!!!
Sorry Zwede, I'm just checking to see if TT is aware tonight
Bearing seal is backwards,spindle is beat on, journal damaged,new bearing useless, charges to the owner by this Bozo should be criminal!!!
BTW- the original shims used with the new bearing for both spindles were .012-.016" too big,that's why Bubba couldn't just replace the bearings- you have to check each bearing setup.
Ok I've had enough of this fun for today, I'm going home!!
Gary
Old Dec 25, 2005 | 02:56 AM
Burnt71's Avatar
Burnt71
Gary , One last problem Could you give me the part number of the back seal . I tried using Federal Mogul part#9178s The rubber seal part is flat across.I can't slide on the back splined yoke without smashing the rubber seal.
Old Dec 26, 2005 | 10:58 AM
GTR1999's Avatar
GTR1999
I tried to yesterday but the forum was down.
NAPA inner seal 16757 about $13 list
NAPA outer seal 19803 About $16 list
Gary
Old Dec 26, 2005 | 01:57 PM
  #33
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Gary
auto zone is a little cheaper.
TIMKEN
INNER 9178S $10.89
TIMKEN
OUTER 5113 $9.99
NAPA be proud of their sheit.
Old Dec 26, 2005 | 02:45 PM
  #34
Burnt71's Avatar
Burnt71
Old Dec 26, 2005 | 03:40 PM
  #35
Retro78's Avatar
Retro78
Gary... you do great work as usual and also not afraid to share your techniques with us. Thanks! I don't like the rough feel of one of my TA bearings that was done by someone else two years ago. I will be using this thead to guide me through it.
Old Dec 27, 2005 | 07:55 AM
  #36
GTR1999's Avatar
GTR1999
Thanks Doug, I know you can do the job and that "other guy" near you will help if you have a problem too.
Turtle- Those Timken seals- are they angled or straight? I haven't used them and would be curious to see what they look like.
Gary
Old Dec 27, 2005 | 08:27 AM
  #37
comp's Avatar
comp
thanks again
To Rear Bearign Rebuild
Old Dec 27, 2005 | 09:51 AM
  #38
goinbroke's Avatar
goinbroke
Gary, I used Timkem 5113 on my outers. The rubber was straight. I had to use the Federal Mogul 9178S on the inner.....they were also straight.
Burnt71....when the yoke is installed it "flares" the rubber inward creating the lip. It has a pretty fair amount of "grip" so be sure and put some grease on the rubber.
Old Dec 27, 2005 | 10:31 AM
  #39
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Gary, great job and you make it look so simple.....I have one question though, i think i understand the concept of this (ok maybe not) any way heres the ? with the set up tool, since it lets you set up everything on a shaft that is slightly smaller so you can get the parts on and off, and find the correct shims, and measure everything....but how do you know that everything you mesured for on the setup shaft is going to be correct for the real axle shaft? thanks bob
Old Dec 27, 2005 | 11:17 AM
  #40
goinbroke's Avatar
goinbroke
Bob....until Gary checks in.......think of it as establishing a length/distance. The length includes the 2 bearings, spacer, and shim. This length will always repeat itself whether on the setup tool or spindle. The only thing that will change the total length is the thickness of the shim. When you take your endplay check you're essentially measuring the length of your bearings, spacer, and shim (call it spindle setup) against the length of the outer races in the bearing housing. You're wanting the "length" of the spindle setup to be .001 to .002 longer than the housing. You achieve the .001 to .002 endplay via shim thickness. I hope this makes sense.....kinda hard to explain. Gary may be able to do a better job.
