Rear Bearign Rebuild
Old Apr 9, 2006 | 09:48 PM
  #81
brockbenson's Avatar
brockbenson
Default Bolting rear rotors to spindles?
Hi Gary,
Going back a few posts you said you drilled and tapped the rear spindle rivet holes and used flat head allen bolts to keep the rotors on rather than the oem rivets. It's a great idea I thought I would use on my rebuild.
I picked up some allen bolts of the same size you suggested but found that they would sit above the surface of the disk rotor if installed. Did you have to taper the holes in the rotor to make them drop below the wheel mounting surface?
A pic of the bolt you used and verification of the size again would be awsome ..... thank for the great post!
Brock.
Old Apr 10, 2006 | 07:54 AM
  #82
GTR1999's Avatar
GTR1999
Brock you have to use a countersink to set the rotor holes. The iron is soft so it's not a problem. Sink them until the flat heads are below the surface.
Old May 24, 2006 | 09:34 AM
  #83
GruntyPants's Avatar
GruntyPants
I've been poring over these 6 pages of posts and I'm feeling pretty good about tackling my TA's this weekend, but one issue I'm having wasn't discussed. The choices of bearings I'm being offered at the part store are 'Tapered Cone' or 'Tapered Cup'. Which ones should I use, and what are the difference between the two?
Thanks!
Old May 24, 2006 | 11:05 AM
  #84
vetteboy1976kr's Avatar
vetteboy1976kr
Gary,
All of your images are not appearing. Only a box from Photobucket appears that says the image is no longer here. Is it my computer or? Thanks for the great thread!
Old Jun 4, 2006 | 12:53 PM
  #85
hanksters74's Avatar
hanksters74
4th Gear
Hi from Hanksters 76--Ditto on the Photos--They are not comming through here either, but your threads sound fantastic. Thanks.
Old Jun 4, 2006 | 02:35 PM
  #86
GTR1999's Avatar
GTR1999
When I have some time I'm going to repost the steering box, differential and rear bearings pictures as separate posts. I just haven't had time to sit down and do it. If you have questions, I'll be gald to help if I can.
Old Jun 4, 2006 | 05:08 PM
  #87
jimmygmartin's Avatar
jimmygmartin
Hey Gary how ya doin. This is a great post but I came in late and didn't see any of the pictures. As I do most of my own work these shots would be great. I have one rear bearing that is original. I plan on attacking the rear suspension next winter, Ive done these before, but I like your work and may give you a call.
Old Jun 4, 2006 | 08:21 PM
  #88
GTR1999's Avatar
GTR1999
Hey Jimmy,
Just for you I went in and edited this post and added,I think are all the correct pictures~!!
One thing, I mentioned earlier that I thought the early supports didn't have the cast in grease well and the later ones did. Maybe a change over arounf 1970? Well that is wron info, as I did a set of original arms from a 1976 and they had the straight wells. So I don't know if GM used different suppliers or what? The 76's were dated correctly too!
Hope this helps guys. I just did a set of offset arms and will post up some pictures of those too.
Old Jun 8, 2006 | 06:30 PM
  #89
Scott Marzahl's Avatar
Scott Marzahl
Default Rotor shims
Where does one find SS brake rotor shims, I've never heard of them before?
Thanks,
Scott
Old Aug 23, 2006 | 09:01 PM
  #90
SIXFOOTER's Avatar
SIXFOOTER
Gary, any chance you have this thread or a paper on the TA rebuild without all the extra stuff in it?
Old Jan 11, 2012 | 08:08 AM
  #91
STL 71 C3's Avatar
STL 71 C3
Originally Posted by GTR1999
Here's another fancy do dad tool. I call it my spindle holding fixture- old rotor with a flat side cut in to sit flat on the bench while I torque it to 100+ to align the cotter pin hole. Always use new washers and nut too.
Gary
I'm getting ready to tackle this project but lil confused on something...
If the spindle nut requires being torqued to 100 + ft lbs what do you do if the cotter pin does not allign up with hole in spindle?
Keep tightening till it does and dis-regard torque?
Old Jan 11, 2012 | 10:51 AM
  #92
tracdogg2's Avatar
tracdogg2
Yes. 100 ft.lbs. is minimum torque.
Mike
Old Jan 11, 2012 | 04:08 PM
  #93
STL 71 C3's Avatar
STL 71 C3
Mike
Thanks...
Anyone have an idea where to get the mobil 1 wheel bearing grease? Or Timken brand?
Old Jan 11, 2012 | 04:31 PM
  #94
L-82kid's Avatar
L-82kid
You can find GTR1999 on digitalcorvettes,vettemod, CAC, or NCRS.
Old Jan 12, 2012 | 08:43 AM
  #95
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Originally Posted by STL 71 C3
Thanks...
I ordered my Timken grease off Amazon. Just got two tubes while I was at it, they were about $3 a tube a year ago.
Old Jan 12, 2012 | 11:20 AM
  #96
63mako's Avatar
63mako
St. Jude Donor '08-'09
Too bad Gary doesn't post here anymore. He was very helpful to all.
Old Jan 12, 2012 | 11:23 AM
  #97
Tom454's Avatar
Tom454
He's not expected here. He's frequenting a different venue.
To Rear Bearign Rebuild
Old Jan 12, 2012 | 11:27 AM
  #98
STL 71 C3's Avatar
STL 71 C3
WOW...I didn't even look at the thread dates.
Sorry for bringing up an old thread.
What happened?
Old Jan 12, 2012 | 03:38 PM
  #99
Tom454's Avatar
Tom454
What happened?
The usual... 2 forces agreeing do disagree.... sort of. Better left alone lest we be pummeled. LOL
Old Jan 12, 2012 | 04:00 PM
  #100
Mike Ward's Avatar
Mike Ward
What happened?
No personal issues, just a commercial disagreement between him and the site owners.
