Q-Jet Problem
Old Nov 14, 2005 | 10:36 AM
Apocolips's Avatar
Apocolips
Default Q-Jet Problem
I know that this problem has been descussed before, but because it didn't apply to me I didn't pay much attention, now it does! The cast aluminium treads in the carbs fuel inlet are completly stripped. Is there a fix for this problem or do I need to start shopping for a new carburator. Thanks!
Old Nov 14, 2005 | 12:04 PM
lars's Avatar
lars
If you have an early carb with 7/8-20 threads, I can do a correct and permanent repair with a stainless insert. Drop me an e-mail for info and cost:
V8FastCars@msn.com
Old Nov 14, 2005 | 08:27 PM
Apocolips's Avatar
Apocolips
Ttt
Old Nov 14, 2005 | 09:47 PM
GUSTO14's Avatar
GUSTO14
Default Helicoil
You should be able to fix it with a Helicoil. Most good autoparts stores carry them along with the installation tool. Try a local NAPA store. If possible I would take the fitting with you to be sure you get the correct size.
Good luck... GUSTO
http://www.roadstarmagazine.com/modu...rticle&sid=233
To Q-Jet Problem
