Dam(per) dilemma
Old Nov 21, 2005 | 05:29 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Dam(per) dilemma
Is there a quantifiable performance benefit to the expensive fluidampr, superdamper, or whater, over say a heavy duty ZZ4 damper?
Old Nov 21, 2005 | 06:17 PM
big_G's Avatar
big_G
No performance to be gained, it is there to reduce crankshaft harmonics, which can damage the crank.
Old Nov 21, 2005 | 06:56 PM
jdmick's Avatar
jdmick
Don't buy the cheapest one you can find. The timing mark slipped on my cheapie so a timing light is useless.
Old Nov 22, 2005 | 01:43 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Fluidampner is the best.
Yes they can add power, or rather reduce pwr loses.
No matter how well balanced ur rotating assembly is the crank still twists and sees power pusles that can be transmitted to the timing gear set. A good dampner will reduce chain vibration and provide smoother vlv train operation/less power loss from irractic timing gear/cam pulses.
Fluidampner is the best. If using an elastomer (rubber) dampner then the larger the dampner the better.
cardo0
Old Nov 22, 2005 | 07:35 AM
Guru_4_hire
Cruise-In V Veteran
Enough to justify a 200 dollar price difference? Or what about the street dampr?
I am not adverse to the idea of one of these racing things, but at 300-400 bucks these dampers get pretty expensive, and I am not so sure they do it a 200 dollar difference over a Hi-Po OE unit.
To Dam(per) dilemma
