71 Vert - Frame Off Restro Question
Old Nov 26, 2005 | 09:17 PM
b71vette's Avatar
b71vette
Default 71 Vert - Frame Off Restro Question
I have just about finished my frame restoration and getting close to putting the body back on. I will be using the strap harness to lower the body back-on. It is a 71 vert with the hard-top installed. I have removed the seats, carpet,etc.
I have installed the engine, tranny, diff, fuel/brake lines, Should I install the gas tank on the frame before or after I install the body ?
How difficult is it to manuever around the tank with it installed on the frame ?
Any other help tips from those who have done frame-off retros will be helpful.
Thank You
Old Nov 26, 2005 | 09:55 PM
b71vette's Avatar
b71vette
ttt
Old Nov 26, 2005 | 10:07 PM
big_G's Avatar
big_G
Go ahead and set the tank in and leave the straps loose, so you can center the tank after you get the body bolted down. Don't forget the boot and drain tube. Leave the rear valance panel off. The mufflers will be very close, so I would leave them off 'till later.
Old Nov 27, 2005 | 12:46 AM
b71vette's Avatar
b71vette
Default thanks big_G, I have side pipes should
I still leave the valance off?
Old Nov 27, 2005 | 09:56 AM
rponfick's Avatar
rponfick
The only problem I had leaving the gas tank on while reinstalling the body was garage height. The tanks sits up pretty high. Be sure your lift system will go up high enough to clear the tank. Had to take my wheels off and place the hubs on those caster dolly thingys. Give me just enough head room. Good luck.
Yes, still leave the rear valance panel off.
To 71 Vert - Frame Off Restro Question
