big block question
Old Nov 26, 2005 | 10:42 PM
gator79's Avatar
gator79
Default big block question
I talked to the guy who built the motor in my car it was a 1971 454 365 horse motor. he said is was a tonowanda (sp) engine. he rebuilt it and used forged flat top pistons a comp 518 lift 272 duration cam, hedman headers. he sais the heads were the semi closed port heads.
I know nothing about big blocks.what do you think my comp ratio is and any idea on HP.
Old Nov 27, 2005 | 03:42 AM
breathial's Avatar
breathial
If you can throw in the casting number off the heads, that'd help to guess... with the information you have, there's no way to really know...
Old Nov 27, 2005 | 12:15 PM
68/BB's Avatar
68/BB
you need to know how far the piston is below the deck when it is at top dead center, you need to know your head gasket thickness and the chamber volume. normally you would also need the volume of the dish or the dome in the piston but you say these are flat tops so that is not an issue. keep in mind if there has been some milling done on the heads or block this will change the numbers. i would think that the guy who rebuilt your engine knows what the cr is. i cant imagine rebuilding an engine and not knowing that.
Old Nov 27, 2005 | 12:23 PM
Mr big block's Avatar
Mr big block
Cruising
71 454 ,compression is 8.5:1
Old Nov 27, 2005 | 12:58 PM
gator79's Avatar
gator79
I don't think 71's came with flat top pistons .
the builder said the compresion should be 10 to 1 and it should run on 93 pump gas. he also said he built many 454's like this one and they develop 500 to 525 hp. just sounded a little high to me. are the casting numbers under the valve cover?
Old Nov 27, 2005 | 01:24 PM
pauvil's Avatar
pauvil
flat tops on 119cc is about 8:1, 0n 108 cc about 8.5:1 on 90 cc about 9:1 your probably around 110 cc on an iron semi closed, these are with a decked block, as mentioned before, get the head casting no.'s.
Old Nov 27, 2005 | 05:21 PM
blackbeauty74's Avatar
blackbeauty74
Gator79, does your car have a very chopy idle? I was thinking of putting a simalar cam in my 454. Also do you have any problems with your vacume with the power brakes?
Old Nov 27, 2005 | 06:17 PM
Corey_68's Avatar
Corey_68
For what it's woth I'm running that same 272 came in my Small Block street rod. Plenty of vacuum and pretty smooth idle, but in a Big Block with that compression you are leaving mUCH horspower on the table. The smallest I personally would go in a 454 is a 280duration. Step up the came, compression and add headers and it will be a totally different engine.
Old Nov 27, 2005 | 06:29 PM
pauvil's Avatar
pauvil
the 272 does not have a choppy idle, the 282 does, I'm using the 272 on my 454 with .100" domes and 119cc heads, the torque down bottom is insane, this is just under 9:1.
Old Nov 27, 2005 | 07:51 PM
gator79's Avatar
gator79
Default choppy idle
mine definitly has a choppy idle, the builder was going from his memory he built for the previous owner back in 2001. he said the po did not want to change the torque convertor so he put the biggest cam he could with stock convertor. it sounds pretty nasty at idle but it had not been on the road in 12 years so I did not even get into the four barrel ( but it sure was tempting) it may be a while before it gets back on the road I am starting a major restoration.
Old Nov 28, 2005 | 09:51 AM
pauvil's Avatar
pauvil
what kind of vac does it pull at idle?? With flatops on 110cc's you could go to the 282, it won't work great but it will work, you should change the converter with the 282. When you get around 224" and higher duration@ .050 and the centerline changes, you'll losse the cylinder pressure at idle. this gives you the choppy idle. Using a stock converter I've never seen a cam with those specs, unless he was trying to push it and save a few bucks, the 272 does not have a choppy idle. MY crane is a "272" ,that's advertised duration, the lift is.520" and duration is 218 @.050" on 110 cl. It's very very smooth and I can use a stock converter, I use 700 rpm above stock just to bring it up a little into the power range.
Old Nov 28, 2005 | 10:14 AM
zwede's Avatar
zwede
71 454/365 had flat tops stock. Heads were 113 cc and made 8.5:1 CR. With 100 cc heads it's about 9.4:1. Don't know about the "semi-closed" heads. Stock heads were open chamber. If he put another set of heads on it your CR could be anything between 7.5:1 and 10.0:1.
Old Nov 28, 2005 | 11:58 AM
pauvil's Avatar
pauvil
I'm pretty sure the "semi closed" is 110cc. Opens would be 119cc and closed would be the 100cc. He can run the 282 cam but it will run like crap with no cylinder pressure at idle. Stick with the 272 unless your putting in domed pistons. You can do the 282 but I would definatly use a converter with this setup.
To big block question
