Is a Holley 800cfm too big?
Old Dec 12, 2005 | 04:27 PM
Mr.Gearhead's Avatar
Mr.Gearhead
Default Is a Holley 800cfm too big?
My friend has a new never installed Holley 800cfm for $300. I have a 600cfm now on my 355 4spd. It seems to bog when getting off the line but this could be b/c I don't have it tuned correctly...
Do you think the 800 will be too much carb?
My engine is putting out 375-385 HP with 400 lb ft.... not sure if that information is needed.
Old Dec 12, 2005 | 04:52 PM
comp's Avatar
comp
i wouldn't ,,,,some could tune it but not me
Old Dec 12, 2005 | 04:56 PM
big_G's Avatar
big_G
It could be made to work, but it would be happier on a big-block, or big small-block..
Old Dec 12, 2005 | 04:59 PM
norvalwilhelm's Avatar
norvalwilhelm
I think it is a little big but even you manifold determines which carb works best. Your 600 carb actually likes a taller intake and the 800 would work on a smaller intake. When guys tune with spacers they are actually tuning the intake height to compensate for a mismatched carb.
I would go about 750 double pumper but then again I am a fan of double pumpers.
Old Dec 12, 2005 | 09:11 PM
Mr.Gearhead
I didn't know that about intakes... I always thought the carb was determined by horsepower needs... I checked some carb "calculators" and they recommend around a 600 cfm. This is the one true area that I have never tried to play around... I just though it would be easy to buy one for the car instead of jetting and such... My intake is an Edelbrock Performer... I wanted to be able to clear my stock hood without any issue. From your pics... I see you did the same...
So a 750 Vac Sec double fits the bill? Can you tell me what the true difference between a double and single will do for me... THANKS.
Old Dec 12, 2005 | 09:19 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you know i have a speed demon 750 vac sec carburetor and thats probably comparable to a holley 800 cfm. My speed demon works great its not too big for my 355/350 hp engine and i have a performer intake also
Old Dec 13, 2005 | 04:21 AM
stingr69's Avatar
stingr69
You probably need to spend some time with the 600 CFM carb and a manual. It does not matter what size the carb is if you can't tune it. JMO.
-Mark.
Old Dec 13, 2005 | 05:52 AM
kb2fzq's Avatar
kb2fzq
Here we go with my "too much carb?" thing again...
Lars, please enter here....
Old Dec 13, 2005 | 10:34 AM
Brandywine's Avatar
Brandywine
Rebuild the 600. You don't need the 800cfm...
Old Dec 13, 2005 | 01:07 PM
the73vetteman's Avatar
the73vetteman
There's some guidance on carb sizing on the Holley web site.
www.holley.com
lars's Avatar
lars
No way, man... you're not dragging me into this one again..!!
There's no such thing as a 750 Vac Sec double pumper. Vac Sec carbs only have an accel pump on the primary side. Mechanical secondary carbs are double pumpers because you have to have an accel pump on the secondary side to avoid a lean-out condition when the secondary throttles are abruptly opened by the mechanical linkage.
If you're looking for a bolt-on carb that will not require any tuning or jet changing, a used 800 is probably not the best idea. Any carb will require setup and tinkering, so you're just as well off working with what you have.
The 800 can be made to run fine on your car, but it's bigger than you need. If you're going to spend $300, don't spend it on a compromise - save up another $150 and get a nice, new, correctly-sized carb for your application. This, by the way, will still need to be tuned... I run 750 mechanical sec carbs on the engines I set up. Many people have very good luck (and performance) with 650s. Bob's 750 vac sec carb (it's a BG Speed Demon) runs really well on his car and pulls very strong.
Old Dec 13, 2005 | 01:36 PM
norvalwilhelm
I mentioned there is sometimes a need to tune the carb for the intake. Let me roughly explain this.
If you are using the 600 the velocity of the air through the venturi will be high. If the intake is low rise the air/fuel mixture will have to take the turn into the runners at high speed. The gas particles don't want to make this high speed turn so they continue past the ports and hit/bounce off the intake floor and this is fuel seperation.
'The same carb would benefit from a spacer to let the mixture have a chance of making the bend.
Put a 800 on the same intake and the velocity is slower and this will allow the mixture to make the turn into the passages. This carb would NOT benefit from a carb spacer.
Now put the 600 back on a high rise intake, one with more time/distance for the mixture to slow down and make the turn without fuel seperation.
On the mustang with a 355 I like to run a 750 double pumper. I find there is not guessing if the secondaries are opening/ when this is happen and you control when and how they open.
I also like the 4 corner idle.
Properly tuned they are a very responsive carb.
I run two 850 double pumpers, 4 corner idle on my 460. Great on gas and never the slightest hesitation when pushed.
Old Dec 13, 2005 | 02:56 PM
kb2fzq's Avatar
kb2fzq
Fair enuf!!
Old Dec 13, 2005 | 03:11 PM
bobs77vet's Avatar
bobs77vet
thanks again for setting it up...its still running great!!!! when are you coming back east???
Old Dec 14, 2005 | 01:19 PM
Mr.Gearhead
yeah... WHEN YOU COMING BACK EAST?
Old Dec 14, 2005 | 01:22 PM
lars's Avatar
lars
Chill the beer and send me a plane ticket. I'll be there with tools in hand.
Old Dec 14, 2005 | 06:38 PM
cv67's Avatar
cv67
St. Jude Donor '05
Couldn't use a full 800 cfm on its best day. You'll have more snap with the 600
Old Dec 15, 2005 | 09:37 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Once again..I'm with Lars here.
I love big carbs, but the 800's I've used before always were sort of a morphodite sorta deal. They were much "fatter" throughout the entire curve and were trickier to get set right. They were great on a typical high 10 sec small block high compression (13.00) race car type deal. With a little work they were fine, but you have to have some experience with them to get it perfect.
Something like the old basic 4779 Holley 750 DP is about the most universal carb out there. It will run well on anything with little effort.
JIM
To Is a Holley 800cfm too big?
