Vortec Numbers
Old Dec 13, 2005 | 04:20 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Vortec Numbers
Its that time the time to start getting my parts for my top end of the motor to try to fix what bubba built me. I am looking for those who run vortec heads. What are your hp/tq numbers and what setup do you have or what is a good set up. I am buying the sdpc upgraded vortec head to accept .550 lift. So any info is appricated. I am looking to get about 400hp/tq thanks
Old Dec 13, 2005 | 04:29 PM
majic1984's Avatar
majic1984
Read under
http://superchevy.com/tech/0312sc_dm15/
THE BEST BUILD
Through all this we've learned that there are certain ways to build an engine to give you the best power-per-dollar. And the best thing is that all the combinations we've tried so far would be easy for you to duplicate yourself. Perhaps the best combination for the money we've tested has to be the Vortec iron heads and COMP Cams XE262 camshaft with an Edelbrock Performer RPM Air Gap intake we ran in DM Part 6 (February 2003). This engine made tons of low-end torque and still managed over 415 hp--and all from a very affordable and streetable package that even makes enough vacuum for power brakes.
T15--DM Part 6: GM Vortec iron heads SDPC PN SD8060A (64cc chambers, 170cc intake runner volume, 1.94/1.50 valves) with Comp Cams 1.6:1 Magnum roller tip rockers PN 1418-16, Edelbrock Performer RPM Air Gap Vortec intake manifold PN 7516 COMP Cams XE262H cam (262/270 advance duration, 218/224 duration at .050, .462/.469 valve lift, 110 lobe separation) straight up.
RPM TQ HP
2600 379 188
2800 384 204
3000 404 231
3200 427 260
3400 433 280
3600 435 298
3800 437 316
4000 432 329
4200 433 347
4400 434 364
4600 439 385
4800 433 396
5000 423 402
5200 411 407
5400 401 413
5600 389 415
5800 365 403
Max 440 416
Avg 417 333
The Vortec heads we tested have been the best bang for the bucks of anything we've tried so far. The TFS aluminum heads are a close second to these iron units.
Old Dec 15, 2005 | 02:04 AM
tigers123's Avatar
tigers123
Old Dec 15, 2005 | 11:26 AM
pauvil's Avatar
pauvil
I love me them Vortec's
Old Dec 15, 2005 | 03:36 PM
comp's Avatar
comp
OK ,,,,
To Vortec Numbers
