Demon carb rages
Old Dec 15, 2005 | 09:47 AM
Grutzy's Avatar
Grutzy
Default Demon carb rages
As it turns out, the main culprit of my new Demon carb leaks were related to the secondary diaphragm. I changed it and checked a few other things and stopped the gasoline shower display. I then started up the 454 behemoth and it ran like it had never run before; crisp and responsive. The Holley that it replaced was bought brand new a short time ago, so it was not a worn out carb. After installing the Demon, I then sent the car to my mechanic, "Rickracer", who worked on some things, as well as observed the performance with the Demon. He is also quite pleased with how much better the engine is running with the Demon carb over the Holley. The Holley was a gas dumping pig and the car was sloppy as hell with it. The Demon I am using is an 850 Mighty Demon w/annular boosters. I don't know how anybody can compare a Holley to a Demon based on what I have experienced. "Rickracer" was the person who advised me to make the switch and I am glad that he did. The difference is astounding, to say the least.
Hype doesn't mean a thing in the real world. Results speak the truth and time always reveals the truth. The Demon wins by KO in first round BLOWOUT!! I will just throw the Holley in the garbage can where it belonged since birth.
Old Dec 15, 2005 | 09:50 AM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Demon Rules All!!!
Old Dec 15, 2005 | 10:19 AM
Older Than Dirt's Avatar
Older Than Dirt
Originally Posted by Grutzy
Anybody want a black smoke bellowing sh*tpile carb for $25? Actually, I will just throw the Holley in the garbage can where it belonged since birth.
Why not post it on the christmas gift give-away thread? Surely someone will want it.
Old Dec 15, 2005 | 10:24 AM
Ganey's Avatar
Ganey
It's great that you have it running right.
Are you running the Torker II intake?
You could send that junk Holley to me.
Old Dec 15, 2005 | 10:25 AM
big_G's Avatar
big_G
I'll take it, and I'll pay the shipping.....
Old Dec 15, 2005 | 10:35 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Glad to hear she's running well
Old Dec 15, 2005 | 10:42 AM
lvrpool32's Avatar
lvrpool32
I luv my demons.............all three of 'em
Old Dec 15, 2005 | 10:51 AM
JoeRags's Avatar
JoeRags
How old was your Demon? almost new you say?
Old Dec 15, 2005 | 11:07 AM
Grutzy's Avatar
Grutzy
The Demon is brand new. I was tired of the Holley and felt that it was worth the experiment to find out the truth about the two carbs. I was hoping that the low rpm sluggishness was carburetor related and man, was I correct!
I am not cruel enough to send the Holley to any members here. I'll just dump it in the garbage where it belongs. The Holley did not even have 500 miles on it. The car never ran correctly with the Holley on it and was always sluggish up until about 2000 rpm's. Originally, I had a dual plane Chevrolet high rise intake but now there is a Weiand TeamG open plenum on it. The Holley was too rich no matter what else was going on. I might even sledge hammer the Holley rubbish in grand ceremonial fashion before the illustrious dumping takes place. Hell, if I get in the mood I might go buy another one at the local speed shop and sledge it right in front of the salesman, just as a statement. Then again, that would support the company that makes the junk even more. As you can tell, I don't have any respect for money and even less for Holley's at this point!
Old Dec 15, 2005 | 11:08 AM
Grutzy's Avatar
Grutzy
Running well? The car is scary! Thanks for the encouragement!
Old Dec 15, 2005 | 12:24 PM
redc3's Avatar
redc3
whoa dude! the demons are just copies of hollys. albeit with major tweaks.
Old Dec 15, 2005 | 12:44 PM
Grutzy's Avatar
Grutzy
Don't believe the hype. If what you are saying were true, my 454 would not run so much better and it does. "Rickracer" told me that the Demon carbs have far superior machining which allows them to be more accurate. All I know is that the engine runs 100 times better with the Demon than it ever did with the Gas dumping pig, Holley. God bless Barry Grant, even if he does advocate a gasoline shower every now and then to his new partrons.
Old Dec 15, 2005 | 03:07 PM
LiveandLetDrive's Avatar
LiveandLetDrive
I had some trouble at first in the form of float adjuster gaskets which led to the carb pissing a 3ft stream of gas. It never showered me but I was more than a little worried that it was going to burst into flames. Anyhow with new, better gaskets and replacing an O-ring that I split (that was bypassing the needle/seat and dumping into the secondaries), it runs like a champ. Started, warmed up, and ran in sub-freezing weather today without a qualm.
-Chris
edit: I agree you're a little haywire in your hatred of Holleys though They've been on hundreds of thousands of performance cars for decades, you either had a fluke or *ahem* operator error. Still, they can have my Speed Demon when they claw it from my cold, dead grasp
Old Dec 15, 2005 | 04:58 PM
694speed350's Avatar
694speed350
Please dont destroy the holley i would be glad to have it. would be glad to buy it and pay shipping.
Old Dec 15, 2005 | 04:59 PM
comp's Avatar
comp
Old Dec 15, 2005 | 06:58 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
First of all I am glad your car is running good.
Have heard similar stories many times here. Usually it is a 20 year old Holley that was on the car when someone bought it, the motor run like crap. THe guy buys a brand new Demon and now the motor runs great. So are Holley carbs crap or would the car run just as good with a new Holley. A properly tuned Holley would run just as well on your car. Give it to a forum member and he will prove my point
Old Dec 15, 2005 | 07:52 PM
Grutzy's Avatar
Grutzy
The Holley I have is practically new and NEVER ran anywhere near as well as the Demon. It ran ok from midrange on up but it is an archaic junkpile compared to the Demon. The Demon ran great right out of the box as soon as I fixed the leak. The response right off of idle was sluggish on the Holley and is crisp on the Demon, even when cold. Does anybody else want to tell me how good the Holley is?
To Demon carb rages
Old Dec 15, 2005 | 07:59 PM
Grutzy's Avatar
Grutzy
I think the Holley would be too large for your car. It is an 850 double pumper. I would be willing to give it away to the member who is most in need of it. That is, if I am able to restrain my destructo reflex!
Old Dec 15, 2005 | 09:27 PM
bryan717's Avatar
bryan717
Whats actualy wrong with the holley? Is it something that Lars could cure? I currently have a 750 holley, its one of those with the 4 corner idle ajustments, the mechanic at the shop says its a trick carb. But I wonder if the 750 may be a little small for my modified 454.
Old Dec 15, 2005 | 11:16 PM
billla's Avatar
billla
St. Jude Donor '14
From my recent experience I believe the Demon carbs seem to come tuned closer to a "typical" application based on the CFM of the carb. I had to pull *6 sizes* of primary jets out of the 3310 I bought for my LT-1 (10.2 CR) style 355.
If it's not too much of a PITA, how about a quick comparison of jet sizes for the "junk" Holley and the Demon?
