???? is Bump Steer
Old Dec 22, 2005 | 02:46 PM
  #41
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Originally Posted by norvalwilhelm
I'm sorry because most of my specialty things are hand made. You are limited to washers. I have had a machine shop so long I think everyone has access to one. I have been custom building parts for 40 years and it become natural to think in terms of making anything you want.
I guess I could find some bar stock and start there. I'll try Baer and see if they will sell some.
Old Dec 22, 2005 | 02:56 PM
  #42
Budman68's Avatar
Budman68
St. Jude Donor '07
Go kart parts
Another place
Looks like they are easier to find than I thought.
Old Dec 22, 2005 | 04:41 PM
  #43
redvetracr's Avatar
redvetracr
Originally Posted by Taijutsu
For those of us that do not weld, is there a kit? What will I gain in handling?
Rick
Guldstrand sells (or sold) a "bump steer kit", it is a pair of triangular blocks that bolts to the steering arm and the outer tierod bolts to the block. Racers FOR YEARS have been buying this kit (or stealing the idea and making their own) so if it worked for them it will work for you. What will you gain?? in a word "probably nothing" unless your car sees racing action.
...redvetracr
Old Dec 22, 2005 | 05:36 PM
  #44
groovyjay's Avatar
groovyjay
Has anyone used this kit:
http://www.vbandp.com/detail.aspx?ID=583
Any real world comments about it?
Old Dec 22, 2005 | 05:38 PM
  #45
Twin_Turbo's Avatar
Twin_Turbo
Looks like a copy of the guldstrand kit
Old Dec 22, 2005 | 05:41 PM
  #46
groovyjay's Avatar
groovyjay
It sure does...
I'd still like to hear if anyone has actually used this on their cars? I get some BS on the C3-R with the nose heavily lowered. It's on my to do list this winter, I have the BS gauge on order, once it gets here I'll look into it. That seems like a very simple solution if it works...
Old Dec 22, 2005 | 06:19 PM
  #47
norvalwilhelm's Avatar
norvalwilhelm
No real world experience but it will increase your turning radius and costs alot.
Old Dec 22, 2005 | 06:58 PM
  #48
groovyjay's Avatar
groovyjay
No way I would buy one for that price, looks like an easy one to fabricate. Increased turning radius is a big minus in my books. Any chance you might start fabricating more of those custom front spindles?
Old Dec 23, 2005 | 10:23 AM
  #49
hosspowerinc's Avatar
hosspowerinc
Does anyone know where you could get the stud that they use in the steeriods kit? It looks like if you used that with a few spacers it would work well. I was looking for one on the coleman racing site but couldnt find one. Any leads? I should be more specific. Its the outer tierod that bolts into the heim joint.
Old Dec 23, 2005 | 10:38 AM
  #50
Twin_Turbo's Avatar
Twin_Turbo
stud? do they now have an adjustable outer tie rod adjuster? If so..it's most likely from speedwaymotors, it's for use w/ a 5/8th heim joint. No ide why they would supply such a thing as most installers will bolt the kit on and forget about it, the stud is for precise adjustments to set the proper bump steer (actually tie rod angle)
http://www.speedwaymotors.com/xq/asp...qx/Product.htm
Old Dec 23, 2005 | 10:58 AM
  #51
hosspowerinc
Thats exactly what Im looking for. The kit they have comes preassembled with the stud and heim. I guess they have it shimmed approx to get better results but not exact.
Old Dec 23, 2005 | 11:11 AM
  #52
UKPaul's Avatar
UKPaul
Thanks for the info Norval
Old Dec 23, 2005 | 11:25 AM
  #53
norvalwilhelm
This is ok for finding what you need but not for street driving. It flexes too much when the spacer gets longer then 1 inch. I use them to get the length of the spacer and then make a spacer that length and weld it to the steering arm. They even recommend this.
Do not add too many spacers and then continually drive like that on the street. It will bend the stud and it does flex.
I have them and don't recommend them for more then a tool to find what you need to drop the outer tie rod.
As for strut rods I bought 2 beautiful black anodized ones for Doug/carguy4sure 14 inches long, tapped left and right from Grisdale web site info@grisdale.com
These guys can supply any length of strut rod and they are about $13 CDN and rod ends left and right are only $13 CDN also.
