Choke Light
Old Dec 25, 2005 | 08:07 PM
kona's Avatar
kona
Default Choke Light
What will cause the choke light on an 80 to come on and stay on?
Kona
Old Dec 26, 2005 | 12:18 AM
BARRY L-48's Avatar
BARRY L-48
I had the same problem on my 80 and it was a broken wire to the choke,it had actually gotten very brittle from the heat as it was laying against the engine block. I replaced it and the choke light went out.
Old Dec 26, 2005 | 10:05 AM
kona's Avatar
kona
I"ll give that a try tonight. I have already replaced the choke itself and the relay thanks for your help.
Kona
Old Dec 26, 2005 | 02:45 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Kona
make sure the oil pressure sending switch is OK because the wiring runs thru it so the choke does not get any voltage till the oil pressure come up
Old Dec 26, 2005 | 02:46 PM
kona's Avatar
kona
Thanks Clem I had not idea this was the case I will add this to the list of things to check when I get home.
Kona
To Choke Light
