Hood cable snapped, help
Old Dec 26, 2005 | 08:06 AM
benjamincaswell's Avatar
benjamincaswell
2nd Gear
Default Hood cable snapped, help
My 69 hood release cable snapped and I cannot find any access ports or holes to manually release hood. Can anyone help? I will be greatfull.
Fixed the problem, After I posted problem I read a solution by a member to a previous post. who da thunk it. a coathanger.[
Old Dec 26, 2005 | 08:30 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
if your hands are thin enough, try to slip you hand in by the left side release mechanism and see if you can grab the cable that way.. or if you are gumby, come at it from the bottom...
Old Dec 26, 2005 | 09:34 AM
Wrecked82's Avatar
Wrecked82
This is such a common problem, I don't know why everyone doesn't replace the hood cables as one of the first things they do. Not expensive at all.
Old Dec 26, 2005 | 09:54 AM
Jims79's Avatar
Jims79
One of my biggest fears, I replaced the top cable in the engine compartment. I will replace the release cable over the summer. What was the trick to getting the hood open.
Old Dec 26, 2005 | 09:48 PM
benjamincaswell
2nd Gear
Hi jim
I don't know about a 79 mine is a 69. I got the tip from a member.
lay on ground by the side vents, shine trouble light from bottom and look through 2nd side vent. you will see a flang with a hole on it and a coat hanger fits perfect. Pull down and voila...I could'nt believe it, I havent driven it for 5 months.
Ben
To Hood cable snapped, help
