Need new trans
I want to go to a 200-R4. My understanding is that one will fit in with out shortening the drive shaft. I would like to buy the transmission already built. I have several questions.
Who would you recommend for a transmission? Bowtie overdrives?
Will the 200-R4 give me a better launch with the 3.08 rear gear?
Should I go to a 3.55 or 3.73 rear gear?
What stall speed should I use with the ZZ4 and a 200-R4?
Is the stall recommendation different for a 3.08 gear and a 3.73 gear?
Can I use my stock shifter?
I am not looking to race the car. I want it to be fun to drive, with good acceleration so I do not get beat by every ricer. I also want to be able to run it down the interstate at 75 mph and get reasonable mpg and rpm. I do want it to be very streetable.
Any help is greatly appreciated.
I strongly recommend you find a local shop to rework the th350 you have,or if you're dead set on an overdrive,have them build and install it.That way there is no way to dispute any warranty issues that may arise.
The 200r4 is a direct fit with no alterations to the drive shaft needed. Yes you can use your stock shifter but you will either need to file another detent in the plate or you can by the kit for $90 that comes with the new detent plates and an indicator lense that shows OD.
Your stock crossmember will also work but you will need to do alittle welding to make it right. I purchased the tube crossmember from Bowtie a direct bolt in that made the job look a whole lot cleaner.
Hope this gives you an idea which way to go. Remeber this if you should go with Bowtie and you have a problem they won't be right down the street like your local Trans shop will be.
Kona
Mine was a universal that would bolt in either Chevy,Pontiac or Olds. Think it has 10 mounting holes and one thing I remember for sure is that if the Bell housing has a crown or bump in the center of the top it will fit.
Sounds confusing let me know if I can help in anyway. The shop that did mine was Riverhills Automotive here in Kerrville 830-257-8727.
Stuart
All the local trans shops have told me the TH350C is not worth rebuilding and if I want a TH350 I will have to get cases and all as the 350C is much weaker.
Local trans places also say the 200-R4 cant be built to handle any real power.
That is why I am looking at something like a bowtie overdrive or an Art Car.
How much stall should I be looking at for the converter? Does the stall depend on rear gear or more on engine RPM?
Maybe I will investigate some trans shops frather from home also.
A local shop here in Orlando quoted me $500 for a bench job (I bring them my TH350 and they re-build it, then I get "my" TH350 back) ... better mark and stamp your parts so you can be sure you get your stuff back...
I would not go thru all the pain of making a different tranny fit unless it's a 5 speed manual with OD
Just ordered a TH 400 street/strip manual automatic with 2000 stall converter from Jackson Preformance for $ 900 shipping included. I`ll let you guys know how it works out. best price out there i found.
A level 3 unit with a 2800 stall unit. The first gear is 2.57 vs
the Turbo 400 2.48. So your launch should not be must different perhaps even a little better with 3.08. Your problem however will be with 4 gear. With a 3.08 your engine rpm will be way to low for normal highway speed. The engine will bog and chug. Will would def need at least a 3.73 or higher gear to enjoy the beneifits of the 4th gear which happens to be a .67 ratio. Do the math. The TV cable is a PITA. Their TV made easy system sounds cool but unless the geometry is perfect on your carb, you will run into problems with getting everything adjusted correctly. My recomendation is unless you want 4th gear and are willing to change your rear gear, stick with a TH350 or 400. I actually have a TH 400 with a transgo shift kit installed for sale. Good luck. TCI has great tranys and TC's. Good service as well.
Is a Art Carr built 200-R4 or a bowtie built 200-R4 better? I am looking at the level III Bowtie as it will allow for me to increase power of the ZZ4 in the future if I want to. How does a TCI built 200-R4 compair?
It is sounding like a 3.73 gear is about the best choice with this trans. It should give a solid launch but still allow for comfortable hwy curising at 70-75 mph.
Why is the TV cable so hard to set up? Is their a better alturnative to the Bowtie TV cable?
Again thanks for any help.
I have 3:55 gears in my 79, and get a good launch, I was told that if I really want a good launch to change to 3:73 gear. but with the 1st gear of a 700r4, I don't think that's a good idea, too much lost power between 1st and 2nd gear and with a 3:73 gear, I'm not going to be in first very long. However, a 200r4 has the same 1st gear as a th350, so i'd go with a 200r4 and 3:73. I turn about 2700rpm at 70mph, so I would estimate you'd do about 3000rpm at 70mph with a 200r4/3:73 set up. good luck
The OD is .67 in the 200 R4 correct? Would I still really be at almost 3000 rpm with a 3.73 rear gear and a locked converter?
I believe my 80 came with a detent cable. However I do not think when I swapped motors and carbs that the street avenger (holley) carb has the linkage for it. I guess I will have to look at that tonight if I get home before dark.
