CanAm 502 6 link progress
Old Dec 31, 2005 | 03:23 AM
84rzv500r's Avatar
84rzv500r
Default CanAm 502 6 link progress
Bad news... My digital camera is broken, looking for a new one prolly a Sony H1
Good news... The CNC plasma cutter is done, Up and running turning out quality parts.
I've settled on some of the details around the 6 link setup.
I'm using Van Steel HD offset trailling arms and Drag Vette halfshaft loops as an integral part of the setup.
Lower bracket and upper inner brackets will be made of 0.125 wall mild steel square/rectangular tubing with some creative work with the CNC plasma cutter to make it look cool.
I'll be using spacers made of 1" x .250 wall DOM tubing to prevent the bolts from crushing the tubing and to locate the rod ends
The upper inner bracket will be welded to the reinforced differerntal carrier (possibly a completely new fabricated assembly). The lower will bolt to the usual place.
The upper outboard bracket will incorporate the aftermarket trailling arms and halfshaft loops. Construction will likely be plasma cut and welded to the trailing arms from 3/16 mild steel.
We're loading the dimensions into Unigraphics to verify the geometry.
I have everything to build this setup in a jig outside the car except a differental crossmember which I'll either buy one and reweld/gusset or fab a new one from rectangular tubing.
Old Dec 31, 2005 | 03:29 AM
76custompaint's Avatar
76custompaint
Sounds cool, can't wait for pics I saw a post of yours a while ago about aluminum door panels, how's that project going?
Old Dec 31, 2005 | 03:53 AM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
can't waite to see the pics.
Old Dec 31, 2005 | 10:11 AM
84rzv500r's Avatar
84rzv500r
Gotta get a bead roller to finish the door pannels and the interior sheet metal...
This summer after I finish the new garage this spring...
Old Dec 31, 2005 | 05:39 PM
GDaina's Avatar
GDaina
This spring Imma gonna come and visit you...will be a nice trip from Cleveland to break in the rebuilt BB.
Old Dec 31, 2005 | 09:10 PM
84rzv500r's Avatar
84rzv500r
No problem...
To CanAm 502 6 link progress
