'70 Carpet Tucking by Foot Dimmer driver's side
OK, no matter how I tuck and put the side kick panel in I can't seem to get the silly thing to fit correctly so that the dimmer switch clicks on and off. It's as iff the carpet is holding the switch depressed and it doens't pop up as much. Is this just because the carpet isn't softened and worn in enough yet that it moves easily or am I doing something wrong. It seems like the side kick panel on the outside edge is holding the carpet down a bit. But it's installed with the screw lined up etc. Anyone with ideas or hints or tips who has figured this out before? :cool: ~Juliet
Cruise-In III Veteran
Re: '70 Carpet Tucking by Foot Dimmer driver's side (Juliet)
Juliet, I assume you installed new carpet? I can't think of a help answer...except to say that mine is new also...and it won't stay tucked well at the tunnel sides below the center gauge cluster area. Just a thought. On most of the other cars I had, the switch was exposed.. a hole in the carpet. :confused:
Re: '70 Carpet Tucking by Foot Dimmer driver's side (Road Fever)
