Which clutch??
Old Jan 7, 2006 | 06:52 PM
conway62's Avatar
conway62
Default Which clutch??
Im replacing the clutch in my 71 454. I am looking at Zoom, Mcloud, Centerforce and RAM. Any recommendations? I am also installng a TKO 5 speed at the same time. The car puts out about 450hp /480 foot lbs of torque.
Thanks in advance
Ron
Old Jan 7, 2006 | 09:11 PM
rponfick's Avatar
rponfick
I don't see Luk on your list. They are the OEM manufacturer. I installed one in my '69 big block, 435hp and love it. Also have a Keisler 5 speed, but wish I had not used a 3:08 rear end.
Old Jan 7, 2006 | 10:53 PM
LFZ's Avatar
LFZ
some will argue, but i've had great success with a Centerforce Dual Frcition clutch...when installed right..they are great..I'd use one again
Old Jan 8, 2006 | 12:20 AM
GaryS's Avatar
GaryS
I have used Luk and Centerforce on small blocks with nice results. No experience on the others. I would go with something that is OEM equivalent.
Gary
Old Jan 8, 2006 | 12:21 AM
big_G's Avatar
big_G
Centerforce here
Old Jan 8, 2006 | 12:38 AM
Solid LT1's Avatar
Solid LT1
Centerforce but watch the pedal freeplay closley and keep freeplay in proper adjustment for the first 1,500-3,000 miles or you will smoke your new clutch.
Old Jan 8, 2006 | 12:41 AM
Les's Avatar
Les
Another vote for Centerforce DF. No heavy pedal effort, nice smooth engagement, and killer grip.
Old Jan 8, 2006 | 09:54 AM
conway62's Avatar
conway62
Has anyone used the kit that Keisler has available?
Old Jan 8, 2006 | 10:49 AM
Gordonm's Avatar
Gordonm
I have used the Center Force I clutch for years behind my motor and it has been trouble free (and its for sale 5K miles). I plan to use the CF Dual Friction behind the new motor.
Old Jan 8, 2006 | 11:33 PM
glen242's Avatar
glen242
Centerforce II clutch. No problems after 500 miles.
Maybe 400 HP, 450 ft/lbs torque. Will find out in the spring on a chassis dyno.
Old Jan 9, 2006 | 08:38 AM
76stingracer's Avatar
76stingracer
One vote for Mcloud.
Old Jan 9, 2006 | 11:41 AM
75 Hot One's Avatar
75 Hot One
The Keisler clutch is by Sachs- German company that makes clutches for everything, it seems from trucks to cars to F1 race cars. Any experience with Sachs?
Old Jan 12, 2006 | 09:38 AM
conway62's Avatar
conway62
Anyone running a Luk Clutch kit? The tech support at Luk states that the minimum Tourque spec for their origional clutch kit for the 454 is 425ft/lb. This is a minimum spec. Not sure why they rate clutches by minimum specs.
-Ron
Old Jan 12, 2006 | 04:45 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
McLoed here.
Old Jan 13, 2006 | 10:53 AM
shafrs3's Avatar
shafrs3
I have the Keisler Sachs clutch. Seems to be holding fine with no excessive pedal effort in the 650hp version.
Old Jan 13, 2006 | 05:31 PM
Entropy's Avatar
Entropy
St. Jude Donor '08-'09
-Ron
My brother is running one in his 75 which is autocrossed...hard. The car has a strong 355, with an M22 and 4.11 gears. It's been driven for 10 years and still doesn't slip. And it's decent enough to drive on the street. I just wouldn't use it in a parade.
trw
To Which clutch??
