Lemans L-88 headlights
Old Jan 13, 2006 | 09:00 PM
Jim Shea's Avatar
Jim Shea
For you guys with L88 headlamps in your 1977 through 1982 C3s, you can fairly easily install a flash-to-pass headlight dimmer switch (if you have a steering column with a dimmer.) You need to purchase a GM dimmer switch with a fourth blade for the flash-to-pass feature. It is available through GM dealers as 26035237. It bolts right in place of your original dimmer switch on the steering column.
Here is the circuit diagram. It requires a wire from the headlight switch to the fourth blade on the dimmer switch.
Now, if you have an older C3 (1969 through 1976) you could swap your original steering column for a later (1977-1982) C3 column with a dimmer switch. Here is a link to a paper on making the installation.
http://www.corvettefaq.com/c3/77+Col...3Rev01FE05.doc
Jim
Old Jan 13, 2006 | 09:09 PM
TPI BOY's Avatar
TPI BOY
lvrpool32
What make of lights do you have and
where did you get them
Old Jan 14, 2006 | 06:26 AM
PatsLs1vette's Avatar
PatsLs1vette
http://www.fgreggracing.com/index.as...teID=101415373
heres another source for the lights.found it on dc
Old Jan 14, 2006 | 02:29 PM
TPI BOY's Avatar
TPI BOY
Sorry where did you get the light bulbs
Old Jan 27, 2006 | 08:36 AM
cosmicvette's Avatar
cosmicvette
Bump, I am interested in hearing what kind of bulbs are used too. Do you just use the standard size round sealed (or semi sealed) lights.
Does anyone have pics of how the lights attach to that aluminium insert?
Also does anyone with a chrome bumper have pics with these on?
Cosmic
Old Jan 27, 2006 | 08:45 AM
ylose's Avatar
ylose
Originally Posted by cosmicvette
Also does anyone with a chrome bumper have pics with these on? Cosmic
Livr's car is a chromed bumper. Also I have dibs on livrs headlights when he gets bored of them. I expect him to try something crazier soon....
Old Jan 27, 2006 | 09:22 AM
lvrpool32's Avatar
lvrpool32
some pictures on a chrome bumper..........
These maybe on there for a while.....not sure theres anythign better to replace them with (yet!!LOL)
Old Jan 27, 2006 | 09:27 AM
cosmicvette
Oh true, soz didn't realise his was a chromy due to the close-up shots, omg that is a serious looking front air dam he has made!
cosmic
EDIT: Thanks lvrpool32 you posted while I was typing, nice pics! May I ask how you find the amount of light you get from those at night compared to the stock setup?
Old Jan 27, 2006 | 09:37 AM
lvrpool32's Avatar
lvrpool32
Light is a lot better....H4 halogen over the stock sealed beams...took a while to "line them up", but a definate improvement.
Nick
