Quick T56 Question
Old Jan 15, 2006 | 12:27 PM
Iskenderian's Avatar
Iskenderian
Default Quick T56 Question
Well, we bought it. But we plan to mate it up to the origional 350. (and maybe later 454) My question is, Does a T56 require a special flywheel to be mated to an old motor? i want to use the origional LT1 style hydrolic clutch. the 350 in it has a standard 33lb hayes flywheel. Am i going to have to buy a new one?
Robert
Old Jan 15, 2006 | 12:58 PM
Iskenderian
pics coming as soon as i figure out how to post them** this is a test**
Robert
Old Jan 15, 2006 | 02:29 PM
Cooter Tech's Avatar
Cooter Tech
The clutch used with the t-56 on Camaros used a pull type throw out bearing. You will have to use a different fly wheel and clutch assembly and throw out bearing. It works nice and smooth with a hydraulic clutch.
Iskenderian
ok finially worked. This is a strange flywheel. wont hook up to an older engine?
Robert
Old Jan 15, 2006 | 02:34 PM
Cooter Tech
The starter is different also, if you can go get it too, that will save lots of money. I can't help you with the fly wheel connecting to the older engine as I also used a Camaro engine. I thought the bolt pattern was the same on the small blocks.
Old Jan 15, 2006 | 02:37 PM
Iskenderian
Looking at prices. I am concideirng saving up a bit more (when i get back from Iraq) and just getting an LT1 also. They guy *said*
the tranny had 55,000 miles on it. maybe the clutch is still good? thanks for the input.
Robert
Old Jan 15, 2006 | 02:55 PM
Cooter Tech
It can get pricey. The drive shaft will also have to be shortened, you will need a master cylinder for the clutch, the list goes on then the while I am doing this I will fix this problem. It is a good improvement in the car. My best wishes to you on your way to Iraq. "Duck and cover that is what we learned in grade school, in my time!
Roger
To Quick T56 Question
