Do speed bleeders really work......
Old Jan 18, 2006 | 04:54 PM
junkman104's Avatar
junkman104
Originally Posted by Avette4me
i bought one of these...cheap and works like a charm...
I did the brakes on my 81 a couple of weeks ago and built one of these for about 35.00 total. It worked great and only took about 10min to bleed all four!
Old Jan 18, 2006 | 08:55 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
So they do actually work? Ive spent to much time trying to bleed the brakes with vacum bleeders and regular bleeding with not much success.
Old Jan 18, 2006 | 09:28 PM
Daffy2's Avatar
Daffy2
Default bleeder
I use the Motive bleeder and you couldn't pry it out of my hands.
Daffy
Old Jan 19, 2006 | 12:02 AM
Z-man's Avatar
Z-man
I've got the speed bleeders and they work very well IMO...
Old Jan 19, 2006 | 03:17 PM
pkgtaxcpa's Avatar
pkgtaxcpa
I think your point about keeping the tube and collector higher than the caliper is critical. Any air in the tubing will naturally go up thus keeping it from going back into the bleeder screw. I was doing the opposite. I'll have to try again.
Old Jan 19, 2006 | 04:52 PM
pkgtaxcpa's Avatar
pkgtaxcpa
Ed T:
It looks like you used an adapter that fits into the bleeder screw. I have some of them, but I've been trying to use one that fits over the outside of the nipple. What are your thoughts.
Thanks,
Patrick
Old Jan 20, 2006 | 09:05 AM
76 sting's Avatar
76 sting
Originally Posted by Ed T
the better the seal to the bleeder /the less air you will have fight (if you dont have speed bleeders). That little $5 magnetic bottle you see in the pic came from Auto Zone. included were a bunch of black plastic adaptors, one of which inserted real tight into the bleeder. Stick it in & give it a good twist. Give it a try & post back.
Hey folks!!
Now you all have me thinking. I just switched everything to the speed bleeders and flushed all the old fluid out (very dark). Now I am still having the pedal go to the floor (car does stop). One piece that I was reading from you folks is to place the bottle high and not on the floor, which is what I did. What I do not understand is air piece. I thought air could not get back in to the speed bleeders?? If this is correct why should the bottle be placed higher? Also, what is the bottle called it looks easier than what I am doing.
I hope you guys are right, I was about to go out an buy a new booster and master.
Old Jan 20, 2006 | 12:56 PM
76 sting's Avatar
76 sting
you are correct that the speed bleeder shouldnt draw air back in. The bleed bottle/adaptor pictured is what i have used on standard bleeders for a long time. That setup is not needed for speed bleeders (but can be used)and was simply used to take the how-to pic.
The bottle depicted is just a standard brake bleeder bottle found on the rack in any auto parts store. I paid $5 for it yrs ago, they probably cost a little more now.
I regret the confusion and therefore will leave out the part about how the heat from the bulb draws all the air out of the brake system
Thanks....
Old Jan 20, 2006 | 05:04 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Thanks for your expertise Ed.
Old Jan 20, 2006 | 07:43 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
if you are still having problems get two people and do it the old fashion way....push on pedal open bleeder and close before pedal bottoms out....release pedal start again...
Old Jan 20, 2006 | 09:16 PM
DR.Jay's Avatar
DR.Jay
My wife gets a good work out that way.
The corvette is a family project. We have it down to a science all four calipers with tire wheel removal about 1/2 hour, but whee have been doing brake jobs together for almost 8 years.
