305 or 350
Old Jan 16, 2006 | 10:48 AM
dasbrew's Avatar
dasbrew
8th Gear
Default 305 or 350
Hi everyone, I am new to vettes and have a dillema that hopefully someone can help me with. I just bought a 1980 California edition :big in pretty decent shape that I want to fix up as a driver, it came with the 305, my friend who rebuilds a lot of cars is trying to talk me into replacing it with a 350. Should i fix up the 305 and keep it original or go for the 350.
Any suggestions would be appreciated.
Old Jan 16, 2006 | 10:50 AM
kona's Avatar
kona
Do you live in California? If so redo the 305 and keep it legal since you only are wanting a DD. You certainly can build a 350 that will pass just seems to be alot of hassle.
Maybe some folks that have done the conversion can chime in.
Kona
Old Jan 16, 2006 | 11:24 AM
dasbrew's Avatar
dasbrew
8th Gear
No, I live in Florida. I just don't want to bring the value down.
Old Jan 16, 2006 | 11:29 AM
gerry72's Avatar
gerry72
Using a 305 won't start nuclear war (at least not that we know of). If it's just a cruiser that runs well and you have no performance aspirations for it, just leave the 305 in it. As far as value...it's hard to do worse on value than a 305 Cali Vette. Of all the Corvettes, you have the least to lose.
Old Jan 16, 2006 | 11:35 AM
dasbrew's Avatar
dasbrew
8th Gear
I am confused by your reply, do mean that it is not worth alot to begin with or that the different engines would not affect its value.
thanks
Old Jan 16, 2006 | 11:42 AM
jackson's Avatar
jackson
305" is a very durable, reliable motor ... perhaps even a bit more so than venerable 350" due to 305's thicker cylinder walls.
350" is bigger & has more power than 305" ... but not a whole lot more. For a driver you wish to keep original ... suggest you keep the 305".
There's plenty internal stuff can be done to 305" to pep it up.
There's a couple cars around here running thirty-overbore 305" w/ 3.75" stroke crank ... 334" ... they run pretty darn good w/ lotsa of torque.
Old Jan 16, 2006 | 11:53 AM
gerry72's Avatar
gerry72
thanks
Same thing. Calif 305 Corvettes are the least desireable so modifications, like a 350 (or even a 454) do not substantially reduce (and may even improve) its overall value. A bigger example: Replacing the factory LT-1 in a '70 Vette with a 383 is a big hit in value due to the rarity and desireability of the car in its original condition.
People are not beating in the bushes trying to flush out 305 Vettes. Not to say they don't have any value, but you can look up the price guides and they'll show a hit if it's a 305 car.
Old Jan 16, 2006 | 12:35 PM
markdtn's Avatar
markdtn
If the 305 is in good shape it will be OK for a DD. If you want a little more pep, you could Tune-Port fuel inject it. If you want a lot of power you should probably consider a swap to a 350. Even so, I would keep the 305. Never know what the next owner will want, once the numbers don't match, they are gone forever.
Old Jan 16, 2006 | 01:29 PM
75blackray's Avatar
75blackray
Thats wierd but everyone has always told me that the 305 was very unreliable. I always thought that the 327 and 350 were good motors but that the 305 was junk.
P.S. I'm not in any way imlying that your car is junk, dasbrew, I just wanted to see if anyone else feels that the 305 is a somewhat more troublesome engine.
Old Jan 16, 2006 | 03:13 PM
dasbrew's Avatar
dasbrew
8th Gear
I appreciate all of the replies to my post so far, It seems like the majority are for the 305. I am also wondering if there are any more thoughts on the 305.
Thanks very much
Old Jan 16, 2006 | 04:01 PM
fl_rider's Avatar
fl_rider
Default Pretty minimal difference...
The stock 305 in 1980 was listed as 180 HP @ 4200 RPM / 255 lb-ft @ 2000 rpm
The stock 350 in 1980 was listed as 190 HP @ 4000 RPM / 270 lb-ft @ 2400 rpm
Get a free flowing exhaust on the 305 and it will run AND sound better.
Old Jan 16, 2006 | 05:08 PM
holley505's Avatar
holley505
If you got the extra money....
buy a 350 short block (less than a 1000.00).... keep your 305 heads (but work the heads and put in the 1.94 valves about $300.00...Or hell buy vortecs about $500.00 ) get a nice 266 or 270 hyd comp cam about $130.00.
Get a new intake 120.00... if you buy vortec heads ... get vortec manifold $150.00... I am not a huge fan of headers... buy they are cheap 120.00 and a new carb will set you back about 300.00
some chrome goodies... and some labor.
You will have a sweet motor that should get you strong 13s 1/4 mile
305...
Old Jan 16, 2006 | 05:54 PM
marshrat99's Avatar
marshrat99
those above that the 305 is a decent engine. If it were me then I do the least possible to the 305 and run it until I saved enough money to buy a ZZ4 short block or a 350 crate engine.
Old Jan 16, 2006 | 07:23 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
the chevy 305 is good for one thing
a boat anchor
Old Jan 16, 2006 | 08:07 PM
markdtn's Avatar
markdtn
a boat anchor
Have you ever driven a TPI 305 IROC or TransAm? I had an 89 305 5-speed IROC and while it won't run with a Corvette it ran circles around a 5-sp Mustang GT and I have timeslips to prove it somewhere. Supposedly TPI was built around a 305, and they will really surprise you. While I would never build one for myself (cost more to build than a 350), if I had a decent running one I would not necessarily dump it just to have a 350. Hope some of that makes sense.
Old Jan 16, 2006 | 08:15 PM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
I agree,, do not put any money in the 305, your wasting your time.
a boat anchor
Old Jan 16, 2006 | 08:18 PM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
I have an 80 also... Lots built and not a lot of demand in the collector area right now and will probably not be for at least 20 years. Had the same delima...but mine was a 350. You can replace it with a 350 and seal the 305 just in case you keep the vette or someone ever wants to buy it from you with the oringinal numbers matching motor.
However, if you're going to replace the engine...then go with a 383 crate motor or larger... isn't that much more expensive and you will wish you did once you get use to the 350 hp and tq... I have loved my 383 conversion...but...well... am use to it now and am thinking about more. Oh...does it ever end?
To 305 or 350
Old Jan 16, 2006 | 09:03 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
take that 305 and store it somewhere in your garage
Take advantage of Florida's great emission laws, get a 350 short block, aluminum heads, hot cam and some sidepipes
Who knows for how much longer we can enjoy this here in sunny FL ????
Old Jan 16, 2006 | 11:42 PM
Kalway's Avatar
Kalway
I'm going to agree with the majority in saying toss that 305 and put a 350 or even a big block in. One thing you need to do is learn from us '81 owners and junk the computer as it has the same system as the '81's L81. The '80 California edition is probably one of the least sought after Corvettes and is mainly due to that 305.
Old Jan 17, 2006 | 01:47 AM
Z-man's Avatar
Z-man
Put a real engine in that car. If someone ever wants the original engine and other parts, you can restore the car to back to original or sell and let the other person bring it back. In the mean time, you can have some fun!
