Distributor Gear Change ?
Old Jan 17, 2006 | 07:44 AM
Hvymtlc5's Avatar
Hvymtlc5
Default Distributor Gear Change ?
I have read that there is an "orientation" on the distributor drive gear. Can someone explain how the gear could be installed 180 out??
Thanks.
Old Jan 17, 2006 | 07:56 AM
markdtn's Avatar
markdtn
I don't think that is true on a Sb or BB Chevy. It is true for some Hondas and Toyotas (and others I'm sure) The gear on those has a wedge on it so it only goes 1 way.
Old Jan 17, 2006 | 08:28 AM
LS-Five's Avatar
LS-Five
East bound and down...
I'm not sure if you are referring to the orientation of the distributor to the cam as a function of timing, or if you are referring to the orientation of the gear itself. If you are talking about the latter, it is possible to put the distributor gear upside down. At first glance you may not notice it to be incorrect, but when you try to drop it in you will certainly figure it out (ask me how I know.) But, if you referring to the orientation of the distributor itself, it is very easy to get one put in 180 out. The easiest way to fix this is with the ole' finger over the spark plug hole trick. Hope this helps.
Old Jan 17, 2006 | 08:33 AM
lars's Avatar
lars
Thanks.
The distributor gear is not symmetrical, and it must be installed the correct way to keep the installed distributor orientation correct. If the gear is installed 180 out, the distributor will not be "clocked" correctly when the timing is set. This is critical on cars with the distributor shielding installed, since there is very little room for distributor movement when setting timing. C2 Vettes with the aluminum manifold cannot be timed if the gear is installed the wrong way, as the distributor will hit the back runner of the intake manifold.
There is a dimple on the distributor gear for the clocking. The dimple on the gear needs to point the same way as the firing tab on the rotor. If you flip the gear 180 the other way, the distributor will be 1/2 tooth off its clocking.
Old Jan 17, 2006 | 08:34 AM
Hvymtlc5's Avatar
Hvymtlc5
I beginning to think this is like looking for a muffler bearing. I had heard there was a stamp mark on the dist. gear that had to be installed one way or another in relation to the distributor shaft or it would be installed wrong....can't see how it would / could make any difference.
Old Jan 17, 2006 | 09:03 AM
redvetracr's Avatar
redvetracr
and if there is no "dimple" look at where the pin goes through (on both sides) in relation to the teeth on the gear, one side lines up with a tooth where the other side splits two teeth. Install the gear so the rotor button is facing the split teeth.
...redvetracr
Old Jan 17, 2006 | 09:11 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
it can be installed wrong and mine was....the reason it can go in wrong is that the retaining pin is off set .....re read Lars comments and see if it is important for your application....
Old Jan 17, 2006 | 10:27 AM
Hvymtlc5's Avatar
Hvymtlc5
Reason that I'm asking (my other post this morning) is that I got the 4545 running good with the Demon and stock HEI. I changed that out with a Mllory HyFire and a Mallory distributor (I put the gear on). Car idles really bad and labors to start at 18 degress initial..the HEI was set the same and it cranked good. I was wondering if the gear could be a factor in the problem.
Can I still set initial timing at 18 degress and really be more advanced than that...due to the gear??
Old Jan 17, 2006 | 10:29 AM
Hvymtlc5's Avatar
Hvymtlc5
Bob, Lars,
If it is indeed on 180 degress out and I still have room to rotate the distributor...it's not a problem right?
Old Jan 17, 2006 | 10:48 AM
lars's Avatar
lars
If the gear is installed 180 off, it does not affect the timing or the operation of the engine - it only affects the clocking of the distributor in the engine once the timing has been set - it's cosmetic as long as the distributor has no interference with other engine components. It would not be the cause of your rough running or a miss.
It makes a difference because the pin hole in the gear is drilled from a "tooth" location on the one side, and exits at a "valley" location on the opposite side. If you rotate the gear 180 degrees on the distributor shaft, you effectively change the relative position of the distributor shaft a full tooth from its normal orientation. This is then made up by twisting the distributor that much farther when you set the timing. Normally, a correctly timed HEI distributor will be visually "square" in the engine compartment (the coil on top appears square in the engine, with the wires attaching directly 90 degrees on the driver's side). If you rotate the gear to the wrong position, the distributor will be at an angle in the engine when properly timed. This has no functional detriment - it looks cosmetically odd.
Old Jan 18, 2006 | 11:48 AM
Paul L's Avatar
Paul L
Here is the dimple.
Old Jan 18, 2006 | 12:04 PM
lars's Avatar
lars
Good pic, Paul.
Hvymtlc5: If you notice in Paul's picture, the roll pin is aligned with a "valley" in the gear. On the opposite side of the gear, the roll pin is aligned with a tooth, making the gear non-symmetrical in its clocking. If you pull the pin out and rotate the gear 180 degrees, the clocking of the shaft relative to the gear (and therefore the camshaft) will change, and this will change the installed orientation of the distributor in the engine once timing has been set.
Old Jan 18, 2006 | 01:34 PM
Hvymtlc5's Avatar
Hvymtlc5
Very good picture, and a picture speaks a thousand words......checked it last night and the dimple lines up with the rotor pointer....so I'm good there. Must be the Mallory distributor lack of vacuum advance that causing the rough idle.
To Distributor Gear Change ?
