Starter problem
Old Jan 23, 2006 | 01:26 PM
Marcusk408's Avatar
Marcusk408
Default Starter problem
My '82 Vette doesn't start sometimes. I would turn the key, hear a single click, instrument lights would dim for a second and nothing. I think the battery is ok since it would fire right up as if nothing is wrong after a few more turns of the key. This usually happens after the engine is warm. At first I thought it was a heat soak problem with the solenoid since it seems to fire right up in the morning and only act up after driving for awhile but one morning it didn't fire up after sitting over night and I heard the same single click sound from the starter. There goes the heat soak theory. What should I do to check/fix this?
Old Jan 23, 2006 | 01:40 PM
Garys 68's Avatar
Garys 68
Do the simple stuff first. Clean and check connections at battery, starter, and grounds.
Old Jan 23, 2006 | 06:15 PM
mr. creosote's Avatar
mr. creosote
Sounds similar to what my car was doing recently. If your connections are all tight, have your battery load tested at Autozone or somewhere. Mine had a bad cell. Bought a new battery (Optima) and haven't had a problem since.
Old Jan 23, 2006 | 11:21 PM
Marcusk408's Avatar
Marcusk408
I checked and cleaned the connections at the battery and at the starter. It's doing the same thing.
Does Autozone charge for their battery load testing?
Old Jan 24, 2006 | 12:00 AM
Oldguard 7's Avatar
Oldguard 7
No, they do not. They will test it. If the battery is low, have them to recharge it (also free). Let the vehicle sit overnight
and start it again. If it does start,start it up again the following day and repeat until the problem occurs again(hopefully in your driveway). If it does not start, something is draining your battery. You can get a device from the zone that does not permit your battery to drain, but that is just putting a
Band Aid on the problem. Good luck and keep us posted.
Old Jan 24, 2006 | 12:03 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i bet you have a dead cell in the battery, you did clean all battery and ground connections and the starter terminal connections?
Old Jan 24, 2006 | 02:47 AM
Marcusk408's Avatar
Marcusk408
I'm pretty sure the battery isn't low because it will always start right up as if there's a fresh battery; that's when it's not being temperamental. If the battery was weak then the starter would at least engage and try to turn over the engine. My problem is intermittent and I would just hear a single click when it does happen. It's as if the solenoid is sticking periodically and not engaging the pinion in the starter. Maybe I'll just replace the starter and see what happens.
Old Jan 24, 2006 | 07:45 AM
kb2fzq's Avatar
kb2fzq
Exactly....change the starter/solenoid....
Old Jan 24, 2006 | 10:50 AM
wnmech's Avatar
wnmech
I had a chevy several years ago that did basically the same thing and it ended being the starter bad. When the starter motor got hot it required very high amperage to turn the engine over. Autozone will also load check the starter but it should be hot to see if they can duplicate the problem
To Starter problem
