Nitrogen in your tires?
Old Jan 31, 2006 | 03:59 PM
AirMarcus's Avatar
AirMarcus
Default Nitrogen in your tires?
Is anyone using nitrogen instead of air in your tires? I have heard that it decreases tire temps and keeps pressure longer. Is it worth the xtra 5 bucks?
Old Jan 31, 2006 | 04:11 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
don't know where you live, but if all they want is $5, go for it. it reduces temp, doesn't expand and contract as badly as regular O2, is retained in the tire much better than regular air, NASCAR has been using it in their race cars for the past couple of years. if the price is right, it certainly can't hurt.
Old Jan 31, 2006 | 04:20 PM
panchop's Avatar
panchop
seems like a waste of money to me i used to use it at the track in my drag bike tires but only because it was there for my airshifter anyhow. can't see it making any difference in your street car tires.
indy99's Avatar
indy99
From: the land of a never ending frame-off resto-mod. May Visa have mercy on my soul.
Local tire place has free nitrogen with any tire purchase.
Old Jan 31, 2006 | 04:24 PM
rastadr's Avatar
rastadr
why not helium? lift potential? only kidding but since i started, why not nitrous? if you get a blow out at least you'll be laughing. sorry, sick dentist humor.
Old Jan 31, 2006 | 04:39 PM
Twin_Turbo's Avatar
Twin_Turbo
nitrogen molecules are larger than air and therefore don't permeate through the tire so you don't have to check the rpessure as often, also it's "dry" so there's less pressure change with temperature. I say go for it.
Old Jan 31, 2006 | 04:50 PM
Garys 68's Avatar
Garys 68
Since air is about 80% nitrogen anyway, I'm betting any benefit is from being dry.
Gary
Old Jan 31, 2006 | 05:21 PM
Twin_Turbo's Avatar
Twin_Turbo
if <20% of your volume escapes from your tires...what will happen to the tire pressure?
Old Jan 31, 2006 | 05:34 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Commercial air lines have used it for years, don't think they would spend the extra if there were no benefit......
Old Jan 31, 2006 | 06:19 PM
Kenny Bonnell's Avatar
Kenny Bonnell
We use it in the slicks on our funny car, it's much more stable then air. As far as using it on a street car, if it's only a little extra I'd give it a try.
Old Jan 31, 2006 | 06:28 PM
jlaw68's Avatar
jlaw68
wonder if you put helium in your tire and did a burn out would it sound like donald duck?
Old Jan 31, 2006 | 06:29 PM
scotty13's Avatar
scotty13
Helium is for monster truck tires...seriously!!
Old Jan 31, 2006 | 07:15 PM
1BAD80's Avatar
1BAD80
Dodge/Chyrsler puts it in their current truck tires.
Old Jan 31, 2006 | 07:59 PM
edhand's Avatar
edhand
I use nitrogen tanks at work...I might have to give it a shot
Old Jan 31, 2006 | 08:05 PM
gkull's Avatar
gkull
I've been using it for years. Nitrogen doesn't change as much in pressure with temp changes. Here in the southwest US pavement temps canbecome severe in the summer when the air temp exceeds 120 without a cloud in the sky. I don't even go down to Laughlin Neveda in the summer anymore. Las Vegas might be only 110 -112 F Laughlin was 124. My Vette without A/C is terrible
Old Jan 31, 2006 | 08:13 PM
kevinator80's Avatar
kevinator80
You guys don't have anything better to worry about?
Old Jan 31, 2006 | 08:21 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
There is a local tire store around here advertising better gas mileage out of the nitrogen fill. They will do the fill for $5 per tire also. I don't know anyone that has done it though.
To Nitrogen in your tires?
Old Jan 31, 2006 | 08:31 PM
danthony's Avatar
danthony
2024 C3 of the Year Finalist - Unmodified
Basically, the air in your tires is about 75% nitrogen anyway. For street driving, I highly doubt it will make any difference.
Old Jan 31, 2006 | 08:40 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
If it was proven that nitrogen really did improve gas mileage, I'm sure the automakers would be using it on all new cars, so they could post higher MPG on their window stickers.
Old Jan 31, 2006 | 08:54 PM
7T1vette's Avatar
7T1vette
Nitrogen in your tires will have absolutely no effect on gas mileage. It's a load of "hooey" in order to collect your 20 bucks.
