I am getting ready to install a new tempature senson in my 350 sb. I've read that you should not use any teflon tape or RTV on the new sensor. Not sure what to do. Thank's for your advise.
That advice is correct. you shouldn't need to use any teflon on the unit since it is a tapered thread. The other thing about teflon is that it may cause your sending unit to have a bad ground, giving you erroneous information.
When I overhauled my motor I put a new sending unit in. My temp. seems to be running about 20 to 25 degrees high. That is compareing my guage to a infrared thermometer. Also I can watch my guage and when the 180 thermostat opens the gauge shows around 210. So I thought the best place to start would be with another sending unit. Also on the first one I used a sealent. Now not sure what to do.
I just put a new sender in my '68 SB and it came from the vendor with teflon tape on it and it works fine and does not leak.
Roger
Not trying to be a smart a$$ but just because the vendor put teflon on it does not make it right. Yes, in most instances, the gauge will probably still read properly. They did not come with teflon on them and the archives will have many posts relative to this, I am sure. FWIW, I have used teflon in the past with good results, but I was always wary of a false reading.
I use the tape. You don't have to get crazy with it, just a couple wraps. You will still get a good ground and it's easy enough to check after you tighten it up. Just use your multimeter and check for resistance from the sensor to the block. It will read 0, or very close to it depending on the sensitivity of your multimeter.
I've never had a grounding problem due to teflon.
Heck, come to think of it, I don't even think we had teflon tape back then!
Thread tape and pipe dope which are commonly known as thread sealants are really just a lubricant. The taper of the treads are what make the joint and keep it from leaking. When a lubricant is used and you take the joint apart there is very little if any of the lubricant left in the joint if it was tightened correctly.
