My vette was maroon; the PO painted a crappy red over the top. Now I want to strip it and make it midnight blue. I’ve read all the threads on razors, and chemical, and sandpaper. I blew most of the budget on the engine, so don’t have the money to get it media blasted. I’ve done real well with a chemical, sandpaper, razor combination, but don’t know how to get into all the little parts on the inside of the door frame, and under the T-tops. Do you all have any techniques to get to these little areas, or do I even need too? I plan to cover it with PPG epoxy primers and paints after I get it down.
Chemical Striper,and Scotchbrite Pad, Then Lacquer Thinner And Scotchbrite, Use Good Rubber Gloves
Dennis
Bix in a black and white can from Home Depot..use a plastic scrapper to get the top layers off then scotch brite to get the residue. You can use warm water and soap in lieu of lacquer thinner if you use a water soluble stripper like Bix.
I’m using BIX and having a fairly good run with it, but there seems to be about 6 layers of paint and primer. I’ll have to try the scotch brite method for all the spots I can’t get the sandpaper into. I don’t think it helps that I’ve been trying to do this in 30* temps.
I started with just 220 grit wet/dry sandpaper with mine, and it was taking forever. I went to Zip products since they are 5 minutes from my house and got some Spra-Strip and used it. I removed everything down to the last layer of primer and then I sanded it with the 220 from there. I started back on 12/28 and am almost done working for a couple of hours every other nite and every other weekend. I'm lucky that I'm going back to the same color so I'm not touching the door jambs. As far as the "hoop" behind the t tops, I just did that Saturday night and the front edge of it was a pain, but I just kept at it. I wound up taping plastic in place of the t tops to keep the inside clean.
Make sure you clean the car with plenty of water and a good chemical and greese cleaner. Ting works well. Any chemicals not purged out could come throgh the paint years later when it works it 's up with changes in climate.
Ja...the 30 degree temps don't help. Why don't you saturate one panel and then lay a sheet of plastic over the stripper...pad it down and try to get as much air out as possible...
Another thing, why do you want to remove the factory primer? You're just making more work for yourself.
Nice writeup vettfixr, also nice looking ride. Let me know if you ever get sick of those wheels!
Bill
Thanks for the compliments. When I got the car, 20 years ago, I figured I would change out the wheels. But then they started to grow on me and I ended up liking them because they are very unique today. They are original Fenton Fanjets from the '70s in 15x8.5 inch size. I always get comments on them when I go to car shows.
