Piston ring gap
Old Feb 7, 2006 | 01:48 PM
7t6vette's Avatar
7t6vette
Default Piston ring gap
I have a 383 stroker in my 76 vette that has been using a little oil for awhile now. So... I decided to have the heads rebuilt (done) and while waiting for that I pulled all pistons to verify what the rings look like. I do not find any problems but the guy who rebuilt my heads recommended re-honing the cylinders and installing new rings. The engine is bored 060 over and I am trying to determine the correct ring gap. Any suggestions?
Old Feb 7, 2006 | 01:55 PM
VETDRMS's Avatar
VETDRMS
I would follow the manufacture's specs, usually around .0004" per 1" of bore, so a 4.060 bore would require a ~.0016 ring gap. The .0004 is just an example, follow the ring manufacture's (or your builder's) recommendation.
Old Feb 7, 2006 | 02:12 PM
jackson's Avatar
jackson
Default 389"
... and ...
Sixty over ... 4.060" bore x 3.75" stroke = 389".
Thirty over ... 4.030" bore x 3.75" stroke = 383".
Old Feb 7, 2006 | 02:19 PM
lars's Avatar
lars
Any set of rings you buy will have the manufacturer's end gap recommednation in the box. Follow the manufacturer's spec. They're all a little different, so you can't get a spec number by polling for suggestions.
Old Feb 7, 2006 | 02:23 PM
New's Avatar
New
And remenber KB pistons (hypereutectic) it is about double ring gaps.
To Piston ring gap
