Hooking Problems
Old Feb 7, 2006 | 01:48 PM
tater salad's Avatar
tater salad
4th Gear
Default Hooking Problems
I've already posted this under general discussion, I thought maybe someone here might can help. I have a 87 with 400 sbc, 4+3 trans, 375 rear gear, mickey thompson ET street radials 275/40/17. My problem is it spins about 70 or 80 feet, it hooked slightly better 1 time the other day and broke the rear leaf spring, luckily I have a parts car. My question is how can I hook it and not break any more springs?
Old Feb 7, 2006 | 01:53 PM
VETDRMS's Avatar
VETDRMS
I am guessing your talking about at the track?
Have you tried using your right foot? I have managed a 1.72' 60' on a 245/45/17 Falken Street Tire (not DR). I have found that if I lightly "shock" the tires when the light turns, let off momentarily, and then ease back into the throttle feeling for grip I can launch without any spin, and it isn't from a lack of power.
Old Feb 7, 2006 | 03:21 PM
jpatrick636's Avatar
jpatrick636
It might be a good idea to post this in the Drag Racing section.
From what I have learned, Drag Radials are best suited for cars with automatic transmissions. They don't take the hard hit of a dumped clutch well, but do respond to the more gradually applied torque from an automatic. For a manual car at the track, conventional slicks or ET's are better. As for breaking parts, there are guys in the DR section running C4's that would know.
Old Feb 7, 2006 | 09:37 PM
shafrs3's Avatar
shafrs3
Have you tried to post this question in the C4 section?
To Hooking Problems
