What is this?? ( pic)
Old Feb 9, 2006 | 06:41 PM
Rock'n Old's Avatar
Rock'n Old
Default What is this?? ( pic)
Can anyone identify this little object.
I think it is supposed to be connected with a very tiny tube-thing?
This, I know what is, but I just found it, after I have had the car for half a year.
me like . o = o = o = o = o =
Old Feb 9, 2006 | 06:43 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
looks like a oil pressure sending line mount.
Miata seats I take it?
Kid Vette's Avatar
Kid Vette
Fitting for oil pressure gage line?
Old Feb 9, 2006 | 06:48 PM
rcread's Avatar
rcread
Yeah, have you noticed your oil pressure gauge isn't working?
Old Feb 9, 2006 | 06:51 PM
ESC3's Avatar
ESC3
I'm surprised it's not throwing oil all over the motor.
Old Feb 9, 2006 | 06:53 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Rock'n Old's Avatar
Rock'n Old
It was working last time I was driving it, but then it was connected.
The tube, or whatever, snapped off while I was working with someting else. So it has not been driven since that happened.
I have not had a closer look, but is it possible to connect the tube with the same plug, or do I need a new one.?
thanX . .~ ~ ~ ~ ~ ~ ~
Old Feb 9, 2006 | 07:12 PM
ESC3's Avatar
ESC3
You will need a new compression fitting,the local auto or hardware store should have one.
Old Feb 9, 2006 | 07:13 PM
rcread's Avatar
rcread
And don't drive the car until you fix it. You'll have oil all over your engine compartment.
Old Feb 9, 2006 | 09:33 PM
wills670's Avatar
wills670
As other people have told you the fitting is for the oil pressure line.
and do not start the car until you have the line reinstalled.
Also if it broke when you were working on the car I would repl. the entire line. They are plastic and they make a mess inside the car if it happens to break there.
Old Feb 9, 2006 | 09:42 PM
carhound's Avatar
carhound
Which line do you like the best, plastic or copper? I have both and really don't know which to go with.
Old Feb 9, 2006 | 10:42 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I prefer electric gauges.
I saw what happened when a rubber gauge line let go on a 41 Chebby truck. That was NOT fun - especially since the damage wasn't very evident when the pressure was off. It was at the shop for over a week, I spent an afternoon studying every inch of the engine before I found the problem.
Old Feb 9, 2006 | 10:49 PM
GaryS's Avatar
GaryS
There have been posts on other boards about using copper. The gist of the article was that copper is so brittle that you will have an engine oil fed fire some time after you start using copper. Hopefully the copper colored lines are copper plated steel. you can check with a magnet. OTH, all of the parts houses sell the plastic lines and they are easy and cheap to install.
Do not use copper lines.
Gary
Old Feb 11, 2006 | 06:53 PM
swiabill's Avatar
swiabill
if the line is that brittle i would replace the whole line they are cheap and could save ya $$ in the end
Old Feb 11, 2006 | 07:17 PM
kinleydog's Avatar
kinleydog
i replaced mine with a plastic line. still flexible, and the hard cover will not crack or pinch easily. DO NOT RUN ENGINE WITH LINE DISCONNECTED ON EITHER SIDE. BEEN THERE.......
To What is this?? ( pic)
