Help with BB heads
Old Feb 10, 2006 | 12:09 PM
Mr.L's Avatar
Mr.L
Default Help with BB heads
I'm building a bbc 454 +.30 with flat top pistons. I have a nice set of oval port heads #3986133. I know their are truck heads, but I can not find the chamber size. I have looked in many places but they just give year and what they were used on. Before I can order my hyd. roller cam I have to know a approx. size to figure out compression. I have a similar problem with the pistons. I will post a new thread on that.
Old Feb 10, 2006 | 12:13 PM
454_71Stingray's Avatar
454_71Stingray
By truck heads do you mean the so called Peanut Port oval ports? If so probably about 122-128ccs. Do you know what kind of truck they came off of?
Old Feb 10, 2006 | 12:14 PM
Mr.L's Avatar
Mr.L
NO not peanut. Large oval ports. No I don't know what they were on. The person I got them from was using them on a drag motor. I know they were used on the years form 68-90.
Old Feb 10, 2006 | 12:32 PM
454_71Stingray
You could always CC them yourself, Its no too hard just use a syringe and a piece of clear plastic or you can still ball park it with out the plastic. Insert the spark plug for alittle more accuracy.
Old Feb 10, 2006 | 12:55 PM
norvalwilhelm's Avatar
norvalwilhelm
That's what I would do. I bet about 110 cc. The addition of the 2.19 and 1.88 exhuast would help those heads.
They are better then you think and with a little port work, the larger valves and they would out perform the rectangular heads on the street.
The late Lingenfelter claimed they were good up to about 600 horse.
Old Feb 10, 2006 | 02:27 PM
Mr.L's Avatar
Mr.L
The valves mic intake 2.28 exhust 1.95
Old Feb 10, 2006 | 02:29 PM
zwede's Avatar
zwede
From Mortec:
3986133....68-85...oval...OPEN...366T, 427T, 454 Truck
Might help???
Old Feb 10, 2006 | 04:18 PM
norvalwilhelm
I don't think so?? Better remeasure. I don't even think a 1.95 exhuast could be fit.
Old Feb 10, 2006 | 05:06 PM
Mr.L's Avatar
Mr.L
I stand corrected. I took set one out. On the outside 2.20-1.90.
Old Feb 10, 2006 | 08:34 PM
norvalwilhelm
Very impressive for a truck head or any other head. Someone did a great job of installing oversize vavles.
To Help with BB heads
