coil volts?
Old Feb 13, 2006 | 11:44 AM
MSO's Avatar
MSO
Default coil volts?
i have a msd 6a and a msd dist.. what should be the volts at the coil , 9 or 12??
Old Feb 13, 2006 | 11:50 AM
lars's Avatar
lars
Neither. The MSD feeds hi voltage to the primary side of the coil - I can't remember the exact number, but I believe it's in the 200-volt range. Some of the other guys can correct me on the exact number, but you're not running battery voltage to the coil when running an MSD... the primary side can knock you on your butt...
Old Feb 13, 2006 | 11:53 AM
comp's Avatar
comp
Old Feb 13, 2006 | 12:57 PM
jackson's Avatar
jackson
and a lotta meters will not / cannot measure voltage at coil supplied by CD ignition ... careful ... it'll knock yer bic in the dirt!
Old Feb 13, 2006 | 01:16 PM
MSO's Avatar
MSO
i should've been more specific.........what i'm talking about is the volts on the possitive side of the coil, not what the coil actually puts out.
Old Feb 13, 2006 | 01:24 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
12 volts is what ya want to shoot for
Old Feb 13, 2006 | 01:34 PM
kb2fzq's Avatar
kb2fzq
Ahhh, it's the amps that'll kill ya...not the volts..
Old Feb 13, 2006 | 01:37 PM
MSO's Avatar
MSO
i'm only getting 9 volts ..is that ok.. or is there something wrong.
Old Feb 13, 2006 | 01:39 PM
kb2fzq's Avatar
kb2fzq
I believe you should see 12V during engine start then back to 9V...check that..
Old Feb 13, 2006 | 02:42 PM
lars's Avatar
lars
I didn't misunderstand you. The MSD system applies a capacitive discharge elevated voltage to the primary side of the coil - that's the "+" side. With MSD you will get several hundred volts on the primary side, and a resultant increased voltage out the secondary side. If your MSD is hooked up correctly, you will not have battery voltage on the "+" side of the coil like a normal system. That's how the MSD works.
Old Feb 13, 2006 | 02:47 PM
lars's Avatar
lars
I just found the info: On the MSD 6-series ignitions, the voltage supplied to the coil from the MSD (that's going to the "+" side of the coil) is 460 to 480 volts. The stock setup is about 7 volts when running, and battery voltage when starting.
Old Feb 13, 2006 | 04:15 PM
MSO's Avatar
MSO
thanks alot ,, gonna go back out and make sure everything is hooked up right...
Old Feb 14, 2006 | 11:16 AM
jackson's Avatar
jackson
Yep ... hopefully, we all know about the amps being worse than volts thing ... but beware. And I didn't misunderstand either ... I'm talking about high coil primary voltage/current w/ CD ign ... it'll hurt you! I've tried but never measured it because I've never been able to get a reliable reading on several meters ... BUT ... several years back ... up around Gaston SC ... a local racer was working on car w/ his 12 year old son ... CD box & coil inside cockpit ... somehow son got 'hold of it ... IT KILLED THE BOY! I wasn't there, I don't know the medical examiner ... but it was reported locally. Most of us have been bitten by secondary (plug wires) ... not fun but usually not life-threatening. But I've also been bitten by CD ign coil primary voltage/current ... it's STRONG! By the way it felt, I believe the current (amps) was high.
To coil volts?
