Water pump
Old Feb 14, 2006 | 08:36 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Water pump
What are the recommended water pump solutions these days?
Edelbrock, Weiand?
Any data on an affordable short water pump, that performs well?
Old Feb 14, 2006 | 08:48 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
whats wrong with running the stock one? the flow capability is fine for 99% of all applications unless you are running a drag car
Old Feb 14, 2006 | 08:49 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Edelbrock Aluminum here
1BAD80's Avatar
1BAD80
GM makes a great aluminum one. I have one on my motor.
Old Feb 14, 2006 | 09:05 PM
Guru_4_hire
Cruise-In V Veteran
GM huh? I will check it out.
Old Feb 14, 2006 | 09:46 PM
SteveG75's Avatar
SteveG75
GM Performance Parts Aluminum here as well. Nice piece. PN 14011012
GM list is $122. Scoggins Dickey (www.sdpc2000.com) has it for $99.95. www.gmpartsdirect has it for $85.40.
Old Feb 14, 2006 | 10:22 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I have a Weiand Team G on mine. Works fine...but actually the stock iron one did too. But the alumium one is cooler looking!
One thing to look out for is that many of the race type ones need some of the Moroso pulley shims to get pulleys aligned.
JIM
To Water pump
