Just wondering how hard would it be to swap my 1978 l48 corvette to fit in a Older 427, My dad was going to buy one for our impala its a good deal for what you get its cheap n powerful. But i was wondering how Difficult would it be to fit one in, and make it work without Problems?
One of the biggest headaches in the swap is getting all the pulleys and brackets. Big block vettes used the short water pump where as most other big block applications used the long pump. The long pump setups will interfere with the front crossmember.
i can't give u the exacts because i didn't make the change but my 77' has a 454 in her n the girl i bought her from told me it wasn't that bad 2 make the change..........
It will go right in and bolt up to the existing TH350 (possible weak link)There will be some pulley / bracket changes needed. I don't think the SB radiator will be up to the cooling task. And the rear halfshafts are another concern - don't know what size came in your car. There are issues with the AC/Heater box if you every have to pull the passenger head with engine in the car...you cant get the rear head bolt out without cutting the box.
Not hard to do but not cheap either. In fact, it can get really expensive. You will have to change all the accessory brackets,pulleys, and belts. All 68-74 BB Corvettes used the same brackets. Take a look in any Covette vendor catalog for the cost. In addition, you will need to change the exhaust and you should consider upgrading the cooling system and adding heavier front coil springs to accomodate the increased weight. This can get really expensive really fast even if you get the motor for free. Take the time to research everything that you will need and the cost for each item then make up your mind.
Good advice... The engines a great deal for the power you get, its from guy my dad found. I always wanted a big block vette, theres nothing that can beat it... Now i do plan on buying sidepipes at the end of summer, so exaust till be fine.
I will probably try and make some phone calls and all, If it wont be to much hassle, i mite do it, But cost is a issue yes. I guess ill try and search for prices and everything.
Other than everything "bigwheel" said, the car is not going to handle (corner) the same with the added weight. Big blocks are capable of huge power for the street/strip (more than the stock driveline can handle) and can be quite thirsty, but todays small blocks can deliver very respectable power for less money and might sip less fuel.
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
I put a 427 in a 73 a couple of years back no problem...as everyone else says get all your brackets ( short water pump) & re core your rad for the cooling. No problem
the notion of bb's not being good on the turns isn't realy true.....unless your talking nascar speeds on the parkay....the way she sits back in the engine bay n there's realy not a big deal with the weight...maybe 200 lbs wich today can almost b wiped out with all the aluminum parts....there is realy no diff between 3600 n 3800lbs.....i know my big block moves great on the parkway.......like i said the weight issue i think is overrated except in racing applications of course.......what say u guys...
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Get the BB front & rear sways, aluminum heads, intake & radiator and you're about the same weight as a SB....you're good to go. Mash the accelerator and hold on......
well, god this seems alot of work, Would i be better off Stroking my 350, I can buy a kit for 859$ with all my bottom end parts.... Then spend about 1.5k on top end parts..... I seen alot of good deals.. But If i stroke my engine id have to take it to a machine shop for how much work...
I say if a BB would have been a factory option for your year (which being a 78 obviously it wasn't) the go big, but since not stick with the SB and stroke it. If you had a 74 or older, then I would say for the BB.
The later C3s will start to appreciate at some point if they already haven't and sticking a BB in a car where it wasn't even an option is going to hurt the value I think. Just my opinion.
For late C3s I'd just go with a big bore and stroked small block. After I upgrade my heads I've decided I'm done upgrading my 355 and am going to just save up to buy one of those sweet new 454 small blocks. So much power and a lot less effort.
