68 frame mount biscuit replacement
Old Feb 16, 2006 | 05:13 PM
AndyMacLeod's Avatar
AndyMacLeod
Default 68 frame mount biscuit replacement
Hi guys
I have a 68 that I need to put in new biscuits at the body to frame mounts. 68 had solid, after that they went rubber. Is it better to put rubber/polyurethane in instead of the steel biscuits?
Andy
Old Feb 16, 2006 | 06:45 PM
b71vette's Avatar
b71vette
Default Change over was in 73 or 74,from
aluminum to rubber. If you go with the rubber it will raise the body approx. 3/8 inch.
Old Feb 16, 2006 | 09:36 PM
GDaina's Avatar
GDaina
Use rubber, the aluminum will crack again. And you will enjoy the ride...
Old Feb 16, 2006 | 10:39 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I'd go with the poly and never, ever worry about it again.
Old Feb 16, 2006 | 10:46 PM
AndyMacLeod
So i assume even with the extra height of rubber/poly it is doable? Is there any worries with the extra height? I assume the steering linkage will give me more adjustment to compensate for the 3/8 extra height? Anyone do this to their 68?
Andy
Old Feb 16, 2006 | 11:12 PM
David68's Avatar
David68
l too will do the replacement routine on my `68 using the rubber kit. As to the difference in thickness - would it be feasible to slice the offending 3/8" from each rubber spacer using a bandsaw? You would increase ride harshness but these cars came with aluminum spacers anyway. Another side effect of the extra 3/8" is exposing the frame rails. Good/bad idea?
Old Feb 16, 2006 | 11:14 PM
GDaina's Avatar
GDaina
Andy
Yep, me, and glad I did...went with rubber and glad I did. You can see the stance of my 68...
Old Feb 17, 2006 | 01:15 AM
yukon988's Avatar
yukon988
I was thinking about this too but I wonder if it would reduce the durability of the rubber. On the other hand, it seems like many who have done this say you can't notice the height difference. Maybe we need to ask for pictures?
Old Feb 17, 2006 | 07:05 AM
jimmygmartin's Avatar
jimmygmartin
My buddy and I both have '68 convertables. I have the original body mounts, he has switched to the rubber. His car has cowl shake, mine does not. He plans to switch back to solid mounts. I would not use rubber, and would be wary of any extra height induced by Poly.
Old Feb 17, 2006 | 07:13 AM
GDaina's Avatar
GDaina
Huh? Cowl shake? What is that? If the car shakes, that is not the problem of the rubber mounts. He has other issues and needs to address those, rather than blame the rubber mounts. Mine is a 68 roadster, I replaced the aluminum mounts with rubber sometime in the mid 70's. Best move I ever made. F-41 suspension and aluminum body mounts make an extremely harsh ride. With rubber mounts, no more fears driving over bumps.
Old Feb 17, 2006 | 07:43 AM
shafrs3's Avatar
shafrs3
Wow, are you the original owner?
Old Feb 17, 2006 | 07:46 AM
GDaina's Avatar
GDaina
no, second, bought the 68 in April, 1969 from Roger Penske Chevrolet, Philly, Pa.
Old Feb 17, 2006 | 08:39 AM
jimmygmartin
Cowl shake is in the windshield/dash area. Convertables of all makes and models are known for this (my wife has a new Sebring Conv with significantly more cowl shake then my '68). My car and my buddies have been garaged there entire lifes (we both purchased them in '76). I disagree that ride harshness has anything to do with the body mounts. If you have a harsh ride it is due to some other problem ie. your suspension.
Old Feb 17, 2006 | 08:44 AM
AndyMacLeod
Thanks for all the replies guys. So to you guys who have made the change to rubber/poly. Did you stick them straight in or have to cut them or modify anything?
Old Feb 17, 2006 | 09:04 AM
GDaina's Avatar
GDaina
No modifications to the rubber...nada..
Old Feb 17, 2006 | 09:22 AM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
My 68 convertible does not have the underdash braces that later cars had. This was the "fix" for cowl shake by GM. Maybe adding these would help your situation and save you from replacing your body mounts.
Old Feb 17, 2006 | 06:20 PM
jimmygmartin
Maybe this was the case on early 68's, but both of our cars have these braces.
To 68 frame mount biscuit replacement
