timing chain cover
Old Feb 17, 2006 | 12:36 PM
palazzopl's Avatar
palazzopl
Default timing chain cover
on a 81 ,350 do you have to lower the oil pan to remove the timing chain cover
Old Feb 17, 2006 | 01:32 PM
SIXFOOTER's Avatar
SIXFOOTER
Yes, the lower lip of the timing cover is between the block front edge and the oil pan
Old Feb 17, 2006 | 01:59 PM
lars's Avatar
lars
No. You can get the cover off without dropping the pan. It takes a little prying, wiggling and force, but the cover will come off without dropping the pan. I do it regularly.
Old Feb 17, 2006 | 02:06 PM
SIXFOOTER's Avatar
SIXFOOTER
wow, didn't know that Lars, thanks
How hard is it to get the cover back on?
Old Feb 17, 2006 | 02:29 PM
C3Racing's Avatar
C3Racing
St. Jude Donor '07-'08
lars is right on that.. you dont have take the oil pan off.
Old Feb 17, 2006 | 02:48 PM
Star79's Avatar
Star79
Of COURSE Lars is right!
You can get it back on if you snip the little tabs off of the back of the cover. Just make sure it's not bent from pulling it off (lay on flat surface to ensure straightness).
I did mine this way last summer, and no leaks so far.
Old Feb 17, 2006 | 03:15 PM
lars's Avatar
lars
It's not the cover itself that really interferes when re-installing it: It's the end tabs on the seal, since the seal gets captured between the cover and the pan. If you trim the captured end of the cover slightly and then trim the pan end gasket "ears," you can pop the cover right back into place with little difficulty. I like to do it "dry" a few times before applying the sealant. Once I've verified fit and installation process, I then apply the Permatex Silicone Sealant, with an extra wad of sealant at the trimmed tab location. I haven't had one leak yet.
To timing chain cover
