So, my car just died in the middle of the road last night. Thought it was vapor lock, left it in a parking lot overnight, and went back this morning. It would crank, but not turn over. Had it towed to a shop. Long story short, the points were burned and the dwell was at 20 degrees. I replaced the points and condenser last month and set the dwell at 30. He filed the burn off the points and set the dwell again and it runs fine.
Any idea what would cause the points to burn or move that far?
I was planning to put in an electronic conversion kit, but would it be worth it to put in an HEI?
condensor probly died. It is there to quickly collapse the magnetic field in the coil and to protect the points. Sometimes they suck. HEI is the answer, I quit running points back in '75
There's nothing wrong with points if you run a good quality set with a good condenser. Points are no less reliable than the module in an HEI, and they're easier to fix and troubleshoot. If you run points to trigger an MSD system and a good coil, you have a top-notch system that will outperform almost anything else on the market.
For parts use NAPA part number CS786 for the points and RR175 for the condenser. I check my dwell once a year, and it hasn't changed in 3 years.
Well the nice thing about HEI is it's very unlikely to leave you stranded. Those of us with HEIs generally love em.
Although I do love my HEI, it has left me stranded. It did the same thing. It just died in the middle of the interstate. Turns out, the rotor broke.
Same thing happened to a friend's 1984, except the rotor literally disintegrated doing 130 mph. Flames and black smoke came shooting out the tailpipes. Nice firework show for us in the Corvette behind him. Fortunately, we found the problem and fixed it along the roadside.
I havent upgraded to the MSD yet, but I am running the following ignition:
Stock distributor
MSD rotor and cap
MSD Helicore 8.0mm wires
Accel U groove plugs
Accel SuperStock coil
"Whatever" condenser/points kit from Advance Auto
The mechanic told me that he has had a lot of problems with those one piece points/condenser kits. I will look up those parts Lars suggested and throw them on.
Those 1 piece units are just like asking for trouble. Lars replaced my points and condensor during the TFB in chicago last spring and the car starts and runs better then ever.
Maybe the points cam was not lubed adequately / or cam is rusty ... wore down the fiber/plastic cam follower ... collapsing the gap.
These days ... consider yourself lucky you found a shop with mechanic who actually knew what to do with points.
As Lars said ... good points & cond ... setup right ... in a good dist ... works real well for a LONG time & easy to fix. Not knocking HEI ... I sold a few dozen of em w/ tach drive last year ... sorry have no more.
Not sure what this means. Is this something I can check/fix/or should be worried about?
The 8-lobed cam that the points follower rides on ... should be shiney with a VERY thin film of grease on it ... if you can see the points ... you can see the cam ... it's right in the middle ... the distributor shaft located directly in center of cam.
Sorry to jump on your thread but I have aquestion for Lars, Can I use your recommendation for points and condenser on a stock 1969 300hp 350?
I guess you know that's your problem right there. Like Lars says, NAPA usually sells better stuff. I've got a set of Blue Streak points on my old truck that I've converted to 12V without a ballast resistor and they haven't required adjustment after more than 4,000 miles. Cheap points in a setup like that will fry right away.
Buy 2 sets of Accel points with the medium weight spring,put the extra set in the storage compartement "just in case". Last time I bought some they were about $15 a set. Condensor is extra.
I am thinking I might just nip this whole problem in the bud and get one of these Accel points eliminator kits . Anyone have experience with them. Is this Accel version better/worst than the others out there?
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
The nice thing about points is that when the engine just dies you can usually start there . I used to keep an extra set of points and condenser in the car at alll times for just such ocasions. Got to the point whre it was a 10 min side of the road fix. The maintenence and ajustment of points is becoming a lost art
I would get my self an engine analyser from sears one that has a dwell setting. and just learn how to do them yourself. its really quite simple. and like i said can be done on the side of the road in about 15 min in a pinch. Plus if we ever get hit with an EMP blast your car will still run
Aslo get an extra set and condesor and keep it inthe center storage area along with a scredriver and a flshlight in case its dark
there ame many people on the forum who have done just that, and been very happy. just search the threads as this is a much debated discussion, ytou should easily find what you are looking for.
its a very simple conversion and yeah you wont have to sit on the side of the road, at least for this reason.
But keep learnign my friend, before long youll know all your cars little quirks and habits, and how to deal with them
Thanks for posting information like this on why your car died, didnt start etc. Because of it I think that I will make a project to replace the points and condensor on my 72. I dont really know how old the set is from previous owner. On my 73 I replaced these last year. But now I have a better Napa parts number to use.
