Another Head Light Thread
Old Feb 23, 2006 | 10:26 AM
bluesilver82's Avatar
bluesilver82
Default Another Head Light Thread
Ok my 82 is suppose to have 2 headlight air relays. There is only one installed on the car that is used to operate two actuators. The Left side head light operates perfectly opens and closes. The right side will open almost halfway then looses pressure or something and drops back in to the closed position. Is it because they are operating of the one relay or is it a bad actuator or a combonation of the two? I would appreciate any of your thoughts or suggestions.
Old Feb 23, 2006 | 04:28 PM
dgruenke's Avatar
dgruenke
I'm not familiar with the exact setup on the 1982, but the earlier models had a vacuum line running to the actuator. If the line had cracks and was losing pressure, the actuator would not function.
Old Feb 23, 2006 | 04:44 PM
kona's Avatar
kona
www.corvettefaq.com
You will find everthing you need there to diagnose the problem and repair it.
Kona
Old Feb 23, 2006 | 05:03 PM
palazzopl's Avatar
palazzopl
also try corvette-101.com..I have an 81 and I'm using one relay now ..Had the same problem,I changed the seal and dust cover on the accuator and its much better now, the drivers side still operates a little faster
Old Feb 23, 2006 | 07:50 PM
shafrs3's Avatar
shafrs3
Lots of folks use just one relay for two headlight buckets without problems. Check your actuator bellows on the offending bucket. They're the ones that seal the actuator shaft to the actuator itself.
Old Feb 23, 2006 | 08:30 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
If the one relay will let the one headlight raise normally and the other starts to come up, I would think the relay is fine. I would think that maybe your actuators are leaking. Usually the actuator "witches hats" are what get torn and leak. Easily replaced.
Old Feb 24, 2006 | 08:43 AM
bluesilver82
Thanks guys,
Where can I buy the dust boot and actuator seal?
Old Feb 24, 2006 | 01:08 PM
LannyL81's Avatar
LannyL81
Eckler's, Mid America, etc...all have the boot and rod seal kits as well as on ebay.
Just be careful when removing the clevis bolt from the actuator rod...spray lots of pentrating oil on the threads. You do NOT want to happen to you what happened to me.
Short version is that the actuator rod broke off in the clevis bolt and I was forced to get a new actuator instead of just replacing the rod seal. So instead of $10 I got to spend $75.
Good luck
LannyL81
Old Mar 13, 2006 | 02:05 PM
bluesilver82
thanks Lanny the withces hat needed replacing now the head lights work!
To Another Head Light Thread
