Rear height adjustment ??
Old Mar 2, 2006 | 05:32 PM
LannyL81's Avatar
LannyL81
Default Rear height adjustment ??
Dumb question: to reduce the gap above the rear tires, do I loosen the spring bolt nuts or tighten them? I am only about four or five threads from the ends of the bolts now....is this why I would need to get longer bolts?
Thanks,
LannyL81
Old Mar 2, 2006 | 06:24 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Default Bolts
You will need to lower the spring ends to lower the car. You will need longer bolts. I just put in a composite spring and got 8 in bolts with nuts from the local catapiller dealer for about 3.50 each. After setting the hight, I drilled thru the bolt and nut and installed a cotter pin.
