pushrod length
Old Mar 4, 2006 | 09:56 PM
81cali's Avatar
81cali
Default pushrod length
what length pushrods should I use? will drop a comp cam 284H in an 81. should I go with stock length?
Old Mar 4, 2006 | 10:06 PM
LannyL81's Avatar
LannyL81
Did you do anything else to the heads or block? If so, then you will need to get a push rod length checker and rocker arm.
If you just went to this cam, this is the one I have in my rebuild, you are probably okay staying with stock length...but still suggest checking.
Later,
LannyL81
Old Mar 4, 2006 | 10:08 PM
norvalwilhelm's Avatar
norvalwilhelm
The trick is to know what you are looking for. If you get a checker push rod how do you even know when you have the correct length????
Remember it is better to error on the short side then on the long side.
Old Mar 4, 2006 | 11:17 PM
81cali's Avatar
81cali
Thanks, maybe i'll just opt for the stock length.........just in case
Old Mar 5, 2006 | 11:50 AM
LannyL81's Avatar
LannyL81
You know when you have the correct length pushrod by watching how the rocker arm moves over the valve tip during a cycle of that valve.
Check our Comp Cams technical page and read the page they have on checking for proper pushrod length.
Later,
Old Mar 5, 2006 | 02:55 PM
comp's Avatar
comp
Later,
To pushrod length
