Dana 44?
Old Mar 6, 2006 | 08:46 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Default Dana 44?
Is it possible to use a C4 Dana 44 center section in a 68-79 C3?
Old Mar 6, 2006 | 11:15 AM
MIKER's Avatar
MIKER
I think that Forum Member, Twin_Turbo, is one who could answer this question.
Old Mar 6, 2006 | 01:43 PM
spikezz4's Avatar
spikezz4
Default Dana 44
Sure, but you better be prepared for some heavy modifications to the body flooring. The 44 comes into the cargo storage areas an inch and a half, so those will have to be cut out and redone to a smaller size. That's just one problem, but will get you started thinking about what all is involved. Possible, but complex and involved.
Spike
Old Mar 6, 2006 | 01:58 PM
Twin_Turbo's Avatar
Twin_Turbo
Tabs need to be fabricated for the frame ad aclamp around the diff pinion area, one that converts the torque bar moutn to a regular pinion mount, you could modify an iron case steel bracket 9the alu 80-82 diff has the miunt cast in) The C4 dana isn't considerably larger than what's in there now. I don't think it comes into the cargo area, there's plenty of room there, the only right spot would be the 2 storage boxes, and then the center section that clears the driveshaft and the pinion area. There's plenty of room there though, I think you can do it without cutting
Do you have a D44?? still looking for one for a good price (usually you see entire rear suspensions being sold, I just need the diff & batwing)
To Dana 44?
