I just installed Perform RPM heads and I'm wondering will the Performer manifold will work with these heads? I already had the performer intake.
I also have a stealth manifold but it appears that the stealth manifold will fir with the Mighty demon carb I have purchased.
I have a Performer RPM for sale with only 1500 miles on it. I just swapped it for a Victor Jr. It fit under the stock hood with a Mighty Demon and a drop base air cleaner from Summit.
I have the Performer 2101 intake on my RPM heads. I did match the intake to the heads though. I looked at the RPM intake and could not see anything different as far as the ports go, both are rough cast, The RPM will give you higher top-end range.
