dead spot on the pedal
Old Mar 15, 2006 | 10:07 AM
rbird's Avatar
rbird
St. Jude Donor '06
Default dead spot on the pedal
When I step on the pedal, the car wants to pause before getting gas into the engine. Or, at least that what it feels like... It does it any any speed or rpm... Anybody knw if this is a gas/air issue, timing issue?
Old Mar 15, 2006 | 10:49 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
A lot of times stumble or hesitationit is a lean condition, could be an air leak at the base of the carb or in the vacuum lines or you could jet up a couple of sizes and see if that fixes it
Old Mar 15, 2006 | 12:17 PM
BKbroiler's Avatar
BKbroiler
My guess is a bad accelerator pump in the carburetor.
Old Mar 15, 2006 | 01:16 PM
lars's Avatar
lars
There are multiple possible causes. In order of occurance:
1. Bad/worn accelertor pump or bad accel pump carb circuit
2. Incorrect timing (retarded)
3. Inoperable vacuum advance
4. Lean carb (various causes ranging from incorrect jetting to low float or jammed power piston)
Good luck with the tuning!
Old Mar 15, 2006 | 07:09 PM
mkflanagan's Avatar
mkflanagan
Old Mar 16, 2006 | 09:27 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Also dont forget about the accellerator cable itself, these stretch over time, and the slack can cause the poor throttle response you describe
.02
Old Mar 16, 2006 | 07:24 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Originally Posted by sweethence
Also dont forgat about the accelorator cable itself, these strech over time, and the slack can cause poor throttle response you describe
.02
wtf...
Old Mar 17, 2006 | 07:24 AM
sweethence's Avatar
sweethence
Originally Posted by Avette4me
wtf...
what can i say, I was in a hurry
To dead spot on the pedal
