overflow hose
Old Mar 15, 2006 | 07:51 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Default overflow hose
Does anyone know what type or size is the hose from an alum. radiator to the overflow tank? 69 small block. I do not remember ever seeing heater hose that small. Thanks
Old Mar 16, 2006 | 12:03 AM
SIXFOOTER's Avatar
SIXFOOTER
I think its a 3/8" ID rubber hose, doesn't have to be pressure hose
Old Mar 16, 2006 | 05:59 PM
c69vete's Avatar
c69vete
St. Jude Donor '07
Can someone explain why it does not have to be pressure hose. It is connected directly from the radiator to the overflow tank. There are no caps or valves inbetween. Seems to me this hose will have any and all pressure that the system has on it.
Old Mar 16, 2006 | 08:31 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Regular rubber fuel hose will handle cooling system pressure. If in doubt use fuel injection hose.
Old Mar 17, 2006 | 05:11 PM
c69vete's Avatar
c69vete
St. Jude Donor '07
Default Hose
Thanks all. Am driving over to Ecklers in the morming to pick up a couple of things. Will ask there what might be available also. If it is just fuel hose will get it from the parts store.
Old Mar 17, 2006 | 05:47 PM
SIXFOOTER's Avatar
SIXFOOTER
it doesn't need to be a pressure hose because the only pressure is bleed pressure after the radiator cap, just over flow. Unless it is a presurised resevoiur and the cap is on the overflow tank. Either way, fuel hose will work, the pressure on the cap is only about 7psi I think
To overflow hose
