1981 Vette Side View Mirror
Old Mar 16, 2006 | 06:13 AM
ckaprolet's Avatar
ckaprolet
Default 1981 Vette Side View Mirror
Hello to all. New to the group. Found this site while looking for a solution. Hope someone can help. On my 81, the drivers side mirror head is loose on the supporting arm. The arm is tight against the body just the head is loose and wobbles. I can't see how to resolve this and the parts book does not breakdown the mirror to show how it mounts. I am guessing remove the door panel and attach from the inside but not convinced that is the correct proceedure. Has anyone seen these mirrors apart that can offer advice?
Let me know,
Thanks,
Charles
Old Mar 16, 2006 | 07:02 AM
chevylit's Avatar
chevylit
Have the xact same problem with My 79 and have been told to remove door panel then remove mirror from door to get to screws
through the bottom of mirrror. Haven't tried it yet because car only
has 15,000 miles on it and I just hate to start taking it apart.
Old Mar 16, 2006 | 08:15 AM
Toms82's Avatar
Toms82
Default 81 mirror
Hi,
Remove the inner door panel, then you have to remove the mirror to access the screws that hold the mirror head onto the base. As I recall, removing the top bolts that hold the front window track in allows you to get to the bolts that hold the mirror base to the door.
Good luck,
Tom
Old Mar 16, 2006 | 09:40 AM
Schwee's Avatar
Schwee
Originally Posted by Toms82
Hi,
Good luck,
Tom
On my '81, I had to remove the glass, too.
Old Mar 16, 2006 | 10:41 AM
moosie982's Avatar
moosie982
What sucks about taking the mirror off is the having to disturb the adjustment of the door glass to the body when rolled up. If you tackle the job yourself just take real good notice of what and where the door glass adjustments are at. Good luck,,,,A real M'fer of a job to do correctly,,,,Peace,, Moosie
Old Mar 16, 2006 | 11:12 AM
LONGFISH's Avatar
LONGFISH
I didn't want to take my panel off either so I cut a large O ring and pushed it in the gap.
It tightened up the mirror just fine.
Kind of a "bubba" fix untill I take the door panel off sometime.
You don't even notice it.
Old Mar 16, 2006 | 12:15 PM
Crash80's Avatar
Crash80
Messing around inside the doors of a Vette is about as much fun as open heart surgery in my opinion. It is scary in there!
Old Mar 16, 2006 | 03:31 PM
chevylit's Avatar
chevylit
I agree, thats why I haven't "opened" Mine up yet. Just hate to
disturb all that "stuff" inside the door.
Old Mar 16, 2006 | 04:25 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I've been spending a lot of time in the door and have to agree. It's clear to me that both heart surgeons and Corvette mechanics must have hands and arms smaller than mine.
Old Mar 16, 2006 | 08:39 PM
nukem419's Avatar
nukem419
Cruising
Yea, just changing the door locks and outer handles can be a nightmare. If you screw up the adjustments on your acuator rods you mite end up locking your self out of your car. This happened too me and I was looking around for a cold knife to remove the rear window before I found out that I could take the T-tops off from the outside with a bent butter knife lol. Maybe I should start chopping cars, I can break into a C3 and get it rolling in under 5 minutes now hahaha. I am not positive but I believe that you need to remove the side view mirror from the door then you can tighten the nuts attaching the head too the neck from inside the neck.
Old Mar 16, 2006 | 10:18 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
if your patient and have gobs of extentions, you can get the mirror on and off without disturbing the window setting. yeah, it's fun, and takes just about as much time as if you did move all the window stuff. anyway, it can be done and the way described above is correct. just remember the position of the rubber grommet thingy between the door and the mirror arm when reassembling. otherwise, your mirrors will be tucked up like the nacelles on the starship enterprise.
Old Mar 17, 2006 | 06:07 AM
ckaprolet's Avatar
ckaprolet
Default It's unanimous...
Looks like I am armed with information now. After I do this I will leet you know how I made out! Thanks to all....
Old Mar 17, 2006 | 07:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by clutchdust
if your patient and have gobs of extentions, you can get the mirror on and off without disturbing the window setting....
You sure can. I did.
Old Mar 18, 2006 | 03:54 PM
ckaprolet's Avatar
ckaprolet
Default I started
Got the door panel off and everything else. That part is quite easy. Problem is a tool to get in there to the small space. I am on a search for that. Following the procedure in the sevice manual makes it easy. Just need the tool. Should be able to get to the aft mounting bolt by just loosening the rear anti rattle bracket and removing the front one. If I had the right wrench it would have been a 30 minute job.
Old Mar 18, 2006 | 08:12 PM
71rdster's Avatar
71rdster
It is a pain. With the window in and up, the window mechanism blocks the bolt holes for the mirror base. Down, the window is in the way. You technically may not need to remove the window, but it may help to do so. After you remove the nuts holding on the sport mirror base. Then you can tighten the screws holding the head in place. You might want to put lock tight on the screws, so they don't get loose again.
Old Mar 18, 2006 | 08:45 PM
jlelec's Avatar
jlelec
Took mine off to paint the car. Removing and putting back is easy. I only had to readjust the window. 832 times before it would roll up and down correctly. You can take it off and reinstall with some 1/4" universal sockets and lots of patience..
Old Mar 18, 2006 | 10:34 PM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
By the way, welcome to the forum. As you can see, there's plenty of knowledge here. Larry
To 1981 Vette Side View Mirror
Old Mar 19, 2006 | 09:23 AM
C3 4ME's Avatar
C3 4ME
I'm in the "I had the same problem" club. Driver's side on my 79. For me, the window, and all door hardware came off the door for paint, so therefore the mirror was no problem to take off. For reasons mentioned above, there is no way I will put the old door handles back on, even if I have to borrow money, I will put brand new ones back on when it comes back from paint.
Old Aug 14, 2021 | 01:40 PM
Biehnbag's Avatar
Biehnbag
2nd Gear
Default Mirror glass replacement
I’m looking to replace the glass mirror on my 81 vette. But for the life of me I can’t find the glass With the mounting bracket for the electric motor. I really don’t want to silicone it in place. Surely someone knows where to get the glass with the snap bracket on it.
Old Aug 14, 2021 | 03:38 PM
vettebuyer6369's Avatar
vettebuyer6369
You are responding to a post from 15 years ago. Good time to start a new thread.
